AMP for endpoints
LSA4
Hi Guys
before i start, forgive me for this post, i just need to be pointed in the right direction.
I have installed a ASA5506 at a client site for a POV, behind their edge firewall. The ASA is sitting on the network just monitoring traffic. It picked up malware immediately.
Now the client is looking for malware for endpoints, i have read and read,
I see there are two deployment modes, Cloud Proxy mode and Air Gap mode.
client already has a virtual environment, so what do i need exactly. where will i monitor the endpoints? On FMC? or Cloud
I want an on prem solution. i have read the deployment guide, but i still feel totally lost, someone please guide me...
yogdhanu
You would get the cloud account credentials when you purchase the amp for endpoint.
For on-prem soulution,
http://www.cisco.com/c/en/us/support/docs/security/sourcefire-fireamp-private-cloud-virtual-appliance/118336-configure-fireampprivatecloud-00.html
http://www.cisco.com/c/en/us/products/collateral/security/fireamp-private-cloud-virtual-appliance/datasheet-c78-733180.html
http://www.cisco.com/c/dam/en/us/td/docs/security/sourcefire/fireamp/fireamp-private-cloud/FireAMPPrivateCloudUserGuide.pdf
this should help.
6 Replies 6
yogdhanu
Endpoint clients will be monitored from Cloud. You can integrate cloud to FMC to check the events there as well.
There is an on-prem virtual appliance for fireamp cloud is available as well.
FMC cannot manage the endpoint AMP clients.
Rate if helps.
Yogesh
So do i setup a session in the cloud?
What is the SKU for the on-prem solution?
do i just run it on a UCS? What software must i download to the UCS? I am trying to draw this solution in my head to understand it properly. Like i said i am completely lost.
yogdhanu
this should help.
let me do some further reading, thanks for the prompt response..
See you soon :)
last question, where do i get the ova file from ,  pic attached
yogdhanu
Your accounts team should be able to provide you the link for that.
