06-17-2016 12:14 AM
can we assign all the 4 ports of a port group to a porttchannel for iSL connectivity . Or should we assign ports from different port groiups. what are the pors and cons of selecting ports from the same port group
Solved! Go to Solution.
06-17-2016 03:21 PM
All the ports on the MDS 9396S are 16G wire rate ! No oversubscription. I think here there is no concept of a port group, which in most cases means oversubscription.
06-21-2016 03:15 PM
That's correct, you don't have the concept of shared or dedicated ports. You can also do a
show port-resources to see how they are configured.
Data Sheet for the 9396S
http://www.cisco.com/c/en/us/products/collateral/storage-networking/mds-9396s-16g-multilayer-fabric-switch/datasheet-c78-734525.html
Up to 96 autosensing Fibre Channel ports are capable of speeds of 2, 4, 8, 10, and 16 Gbps, with 16 Gbps of dedicated bandwidth for each port.
06-17-2016 04:57 AM
Do you mean Cisco MDS 9396S 16G Multilayer Fabric Switch ?
06-17-2016 03:17 PM
Yes
06-17-2016 03:21 PM
06-21-2016 03:15 PM
