06-20-2016 10:51 AM - edited 03-18-2019 06:03 AM
Is it "OK" to mount the Precision 60 or Speaker Track 60 camera system *between* the displays when mounted to the wall? I have seen above-screen, on-wall, above-screen in-wall, below-screen on-wall and below-screen in-wall...
I have a scenario that may require that I mount the cam(s) between my two displays... is this OK? What would be the cons of doing it this way?
Thanks!!
06-20-2016 04:27 PM
You can mount the camera any way you like, above, below, between, beside. As long as the SpeakerTrack cameras can see the entire room and everyone is within it's FOV so the tracking can work.
06-20-2016 05:33 PM
As [@patrick.sparkman] has mentioned, there is no limitation to where you can place the cameras - put them wherever you need to to get the best view of your participants. We have rooms with them mounted on top, below, or in between screens, on walls on sides of rooms, or on ceilings in the middle of a room, all depending on what/who they need to point at.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
06-20-2016 11:29 PM
I agree with Patrick and Wayne.
Additionaly is important to mount camera near display for saving eye-to-eye contact.
For example, you can see SpeakerTrack in MarkZukerberg conference room https://www.facebook.com/zuck/posts/10102893229506671
br Oleksandr
