06-22-2016 12:19 AM
We have one port channel configured in our Customer environment. This port channel has been configured with 4x16Gbps ports inside it. One of the switch port started flapping (up & down) continuously, which caused multiple alerts on many hosts as well as drastic performance slowness on one of the Business Critical application. It caused a major issue and later on after disabling this port administratively, the issue got resolved.
Could you let me know the cause of major impact and port-channel behavior in such rare cases, where because of one port flapping, whole port channel got affacted ? Is it a expected behavor of port-channel of kind of software bug in Cisco MDS 9710 switches running SAN OS ?
Solved! Go to Solution.
06-23-2016 10:59 PM
No, error disable also works for E, resp. TE ports:
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_1_x/1_3/fm/configuration/guide/PortChnl.html
If you misconfigure PortChannels, you may receive the "Error disabled - Possible port channel misconfiguration" message. If you receive this message, the PortChannel's physical links are disabled since an error has been detected.
Please post output of
Switch# show errdisable recovery
06-22-2016 01:29 AM
What is the root cause of the port flapping ?
06-22-2016 02:07 AM
bad cable
06-22-2016 11:39 AM
The port-channel protocol is quite busy, handling a port joining / leaving the PC; this will definitely impact the performance.
06-23-2016 12:27 AM
Thanks for your reply walter
My Only concerns is if the port is flapping why it did not go to errdisabled state by itself.
06-23-2016 12:29 AM
I am assuming since the port was flapping it could have carried data frames since the portchannel sensed it ok and then after some time it went off and dropped the frames
06-23-2016 10:14 PM
Hi, Will this command "errdisable detect cause bit error 5 60s" will help me set port guard on the trunk ports which are portchannel or will it only work on F ports
06-23-2016 10:59 PM
