F3 module on 7710 chassis
reza-koohi
hi all
can i use f3 module in a 7710 series with os 6.2(2)???
i culdnt find a simple yes or no.
I know that i cant use some features but can i use it?
thank you
InayathUlla Sharieff
Yes it is supported.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/data_sheet_c78-728410.html
Inayath
**Please do not forget to rate the post if helpfull**
Inayath
reza-koohi
thanks for help...
i found the problem.
my module is broke. sadly it must have a bad delivery and had some damage i think.
