Network Security
Engage with peers and experts on network security topics such as FTD, FMC, FDM, CDO and ASA.
Cisco CyberSecurity
Labels
Is it possible for the FMC to run a report to indicate what rules are inactive/disabled? What about reporting what objects are not being used?I know beside various items there is a "report" icon, or "export to csv" but this isn't giving me the info I...
So, I'm task with finding if anyone else search or connected to a specific URL in the last 30 days. Does any know if FMC have a way of searching this or generating a report. I have only found ways to create a rule to log it go forward not from the pa...
Hello I am working with a network that has currently 10 router nodes using IPSec tunneling to communicate and encrypt packets between the 10 router nodes over a wan. Using 140.0.0.0/30 (64 tunnels total) for IPSec Tunneling I have consumed almost all...
JNCloud by Level 1
  • 148 Views
  • 5 replies
Hello. I install ASA 5506-X with firepower.But When i install ASDM launcher 1.9, I can't connect ASA firepower in ASDM.I delete ASDM launcher 1.9 and install ASDM launcher 1.8, I can connect ASA firepower in ASDM well.Certificate warning occurs when ...
GaeMi by Level 1
  • 932 Views
  • 2 replies
Unanswered Topics
