06-25-2016 10:55 AM - edited 07-05-2021 05:18 AM
Hi all,
i've trying to reconfigure my access point with multiple ssid's and vlan's. All is working great excpect the connectivity to BVI interfaces.
Clients can connect to both SSID's and belong to the right vlan. But I can't ping from the 1141 any host and no host can ping the BVI address.
Here's my configuration:
Current configuration : 3113 bytes
! Last configuration change at 04:45:48 UTC Fri Mar 1 2002
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
no aaa new-model
no ip routing
no ip cef
dot11 syslog
dot11 ssid Computers
vlan 125
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7
dot11 ssid Phone
vlan 120
authentication open
mbssid guest-mode
wpa-psk ascii 7
dot11 guest
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 125 mode ciphers aes-ccm tkip
encryption vlan 120 mode ciphers aes-ccm tkip
ssid Computers
ssid Phone
antenna gain 0
mbssid
speed basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
interface Dot11Radio0.120
encapsulation dot1Q 120
no ip route-cache
bridge-group 120
bridge-group 120 subscriber-loop-control
bridge-group 120 spanning-disabled
bridge-group 120 block-unknown-source
no bridge-group 120 source-learning
no bridge-group 120 unicast-flooding
interface Dot11Radio0.125
encapsulation dot1Q 125 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid Computers
ssid Phone
antenna gain 0
peakdetect
no dfs band block
mbssid
speed basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel dfs
station-role root
interface Dot11Radio1.125
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.120
no ip route-cache
bridge-group 120
interface GigabitEthernet0.125
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.10.2 255.255.255.0
ip default-gateway 192.168.10.1
no ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
login local
length 0
transport input all
end
Would be really nice if someone could take a look into my config and maybe had an idea : ).
Regards Yannik
06-25-2016 11:57 AM
Yannik,
With autonomous AP's, the BVI has to be the native vlan. So looking at your config, vlan 125 is your native, is the AP management ip on vlan 125? There is no way to change this also.
-Scott
06-25-2016 01:10 PM
Scott, thanks for your fast response.
Yes vlan 125 is our native trunk. On vlan 125 we use 192.168.10.0 255.255.255.0 ip range.
Sorry, but is that what you mean?
I think it looks like the AP won't use the default gateway or something ist wrong with bridge-group 1. Cause it can't ping anything.
06-25-2016 01:21 PM
Bridge-group 1 is used with the native vlan which you have. Since vlan 125 is the vlan the AP management is on, then everything looks fine to me. From the console of the AP, can you ping the gateway of vlan 125? You can always try to set the bvi to dhcp to see if the AP gets a dhcp address. Or connect a laptop to that switch port and verify that the laptop obtains an IP address and you have network connectivity.
-Scott
06-25-2016 02:18 PM
I've set dhcp on. But BVI doesn't get an IP and I can't ping the default gateway. I only get now the following error on ping.
Unrecognized host or address, or protocol not running.
All other client's of the vlan get an ip from dhcp-server.
Clients can connect to the phone and computers sssid and all is working great. I only can't get the management interfaces working.
Yannik
