I have been installing some new 3850 switches and had some problems building a stack of 3 same model types, but different version levels. Stacking the same version level has no problems (all V06 or all V07), but mixing version levels doesn't seem to work.
If I add a single V07 switch to an existing working V06 stack and use the 'software auto-upgrade enable' global command, the logs show that the master switch attempts to upgrade the V07 switch, but it always reports V-Mismatch (when performing show version), and never joins the stack.
PID: WS-C3850-24P , VID: V06
PID: WS-C3850-24P , VID: V07
Switch Ports Model SW Version SW Image Mode
* 1 32 WS-C3850-24P 03.07.03E cat3k_caa-universalk9 INSTALL
2 32 WS-C3850-24P 03.07.03E cat3k_caa-universalk9 INSTALL
Are these versions compatible? Are there known issues?
Any information appreciated.
Phil
