06-28-2016 11:03 AM
Hello team.
What is the difference between the PSS Collector (PSS-CSPCServer-2.5.1-OVF10.ova) and SNTC Collector (SNTC-CSPC2.5.2.1-OVF10.ova)?
These differences might interfere on preview from Portal Smart Services (specially on customer's preview)?
Thanks.
06-28-2016 12:55 PM
PSS and SNTC use different portals and the collector images are configured to upload to each one respectively. An entitlement from one will unlock the GUI for the other, but the actual upload will not work.
07-04-2016 01:38 PM
When the customer have a PSS contract, what is the correct form to give access to customer's CCOID that he may see the datas from collector at portal?
07-12-2016 07:07 PM
If you are referring to devices covered under a PSS contract versus Cisco direct, the customer will be able to see all the device data but the contract details will be masked beyond the service level. This is as expected since these contracts may have multiple customer end users so they need to contact the partner in question for details and support.
Nathalie
07-13-2016 12:57 PM
Hi Nathalie,
Thanks for your reply.
The customer that have a contract PSS ought to open a case directly with the Cisco partner, differently when it is a smartnet contract. How is the correct form to Cisco partner to give access to the customer's CCOID to access the portal? I'm a little confused about this because the trainnings about the collector are related to SNTC Collector. May you give me any guidance or documentation to clarify?
07-14-2016 07:55 AM
Are you asking about access to the PSS portal or the SNTC portal?
07-19-2016 05:26 AM
Hi Nathalie,
It's about PSS portal. I need to know what is the correct form to Cisco partner to give access to the customer's CCOID to access the PSS portal?
Thanks.
