8.2MR2 Beta Availability
Jun 30th, 2016
  • Cisco Employee,
Release 8.2.111.x Beta
8.2MR2 (8.2.121.0) is now posted, the beta process is closed. Thanks for all the feedback!
CSCva43051
Substantial degradation of unicast video performance past 15 clients
CSCva48770
2800/3880: Any DCA event during radio reset is causing cmd-timeout
CSCva26525
8.3 8510 ATF crash task-iappSocketTask iappProcessAtfClientStats+245
CSCva51528
AP BEACON config value is always shown disabled in WLC after AP reboot
CSCva55049
2800/3880: Limit 'best' DCA to 80 MHz instead of 160 MHz
CSCuz71914
Issues in XOR radio[Monitor Mode] when AP mode moved to Sniffer
CSCuw18522
APF-3-WLAN_OUT_OF_RANGE errors filling up msglog on WLC
CSCux55307
AIR-CT5520 crash in dtlArpTask
CSCuy75993
SNMP returns 11ac module present for 11ac aps like 3700/IW3700
CSCuz29885
Flex AP automatically switching to non DCA channels
CSCuz49482
FlexConnect: WLAN config stays in ap-specific on moving from
CSCva06192
Kernel panic: PC is at select_task_rq_fair+0x70/0x65c
CSCva17231
on HA failure, Active WLC RF group stuck on 'HA Standby' & RRM stopped
CSCva25810
Flex AVC profile is not removed from the 3802 AP
CSCva34774
WLC crash at apfReceiveTaskwith reason System Crash
CSCva41168
After few hours operation,Client will get wrong IPv6 subnetwork
CSCva47003
8.2MR2: Kernel Panic on 2800/3880 AP PC is at do_bad_area+0x34/0x88
CSCva47557
Profile:Wrong Group ID reported by 2800/3880 APs cause RF Group failures
CSCva49188
8.2MR2: AAA Vlan override failing on Barabdos AP 8.2.111.30
CSCva05514
3802 AP - cannot allocate 2880 bytes buffer for pool #16 in NSS mode
CSCuz48289
FT-PSK PMF-Optional, EAPoL M2 MIC error on change to local auth-flex
CSCva40348
AP2800: Radio crashed with bad_vector_pc points to halspd_data
8.2.111.30
CSCuz72620
ATF:Clear Atf command doesnt clear AP override to disabled.
CSCuz40509
ATF: config all command needs to have override column
CSCuz20714
WLC crashes on emWeb with Reaper Reset
CSCva30541
8.2 MR2: 3800 XOR radio not reporting noise when in monitor role
CSCva25878
3800 AP not clearing evenlogs on WLC
CSCva29450
DHCP option 60 shows shared_printenv error
CSCva23304
Kernel Panic: PC is at wlRecv+0x150/0x964
CSCva23178
Antenna gain for 1810W APs not returned correct
CSCuz58657
3800 AP: client not  joining with link-encryption enabled
CSCva22748
3800: Failing to change channel in sniffer mode
CSCva32819
AP 3800/2800 crash due to Kernel panic
CSCuz56372
SANITY:ME-3800 crashes with kernel panic
CSCva06132
ME: 1852 SW crashed on process ctrl_rx_task
CSCva06192
CSCva23345
3802 AP Radio FW sensord off-channel stuck
CSCux63449
WLC 8.0.120.0 Crash on TransferMsgPeerSend
CSCuz54125
5500 SSHpmCert Memory Corruption( overrun) on Pmalloc/Pfree buffers
CSCva18981
WLC Crash 8.2.100
CSCva32509
Layer 3 client roam fails on controller running 8.0.134.26
CSCva32819
AP 3800/2800 crash due to Kernel panic - OOM
CSCva37881
mDNS AP 2800 and 3800 does not forward mDNS packets not on native VLAN
CSCva38926
XOR no noise/interference/rogues/neighbors in Flexconnect mode
CSCva32183
Issue in clean air when moved from monitor to client serving
CSCva39041
3800: RRM wrongly trying to set AP1142 to UNII-2 extended channels
CSCva37393
3800: Beacon Stuck - off channel stuck
CSCva30755
3800: Sensord dying after  radio reset
8.2.111.23
CSCuz88260
Unable to handle kernel NULL ptr dereference at virtual addr 00000004
CSCva21709
1800 AP crashed - apsw_watchdog about to reboot with reason: capwapd
CSCva25338
2800/3800/1800 'show ap summary' displays wrong ip for static ip config
CSCuy67885
5520 or 8540 may have no Manufacturing Installed Certificates
CSCuz81177
2800/3800 Cmd timeout, RX Hang seen
CSCva07520
2800/3800 DP ERR>22>mv_dp_msg_check_rx:1747>FW Failure Status for opcode:7...
CSCux82102
AP 3600+11ac module crash on memory corruption for 8.2
CSCva14511
2800/3800/1800 DHCP_OPTION_43 messages not seen on AP console
CSCva13591
3802 AP fails to join the WLC after capwap restart
CSCva19392
2800/3800/1800 ERROR:receiveWlanMsg(): mgmt subtype:0xf len:1423 - dropped event
CSCva20303
5520 Mem Leak %APF-3-LIST_ERR: avc_api.c No entry available in table
CSCuy33972
WLC ssh host-key generate command not having an effect
CSCuz52725
2800/3800- Macbook is sometimes using 2SS rate on uplink
CSCva05657
3802 AP - cmd_to off channel stuck Tx FSM is not Idle & TCQ Verify zero
CSCva12610
2800/3800 -Clients are deauthenticating with EAPOL bcast interval expiry
CSCuz62398
1800 capwap local bcast discovery stops working on upgrade to 8.2.102.125
CSCva16181
2800/3800 Sniffer Mode set on XOR Band fails
CSCva21076
2800/3800/1800 Rx hang detection resulting in multiple radio resets & reboot
8.2.111.15
CSCug98522
PMIPv6: MAG delivering multiple DNS servers to clients
CSCuq05475
Controller GUI shows AP's NAT IP instead of private
CSCut42406
Ct5508 crashed while disabling Mobility oracle.
CSCuu91943
8510 WLC crash while accessing the controller crash file info thro GUI
CSCuw28141
Reaper Reset: Task "SNMPTask" missed software watchdog
CSCuw30129
Debugging logging quickly falls behind real-time
CSCuw36069
Threshold MIBs incorrectly set for WSSI modules.
CSCuw65706
AP1530 WGB Drops Tx used w/ other 1530 WGB in same MAC address range
CSCuw89229
Mesh instability with fast-convergence when  RF link is unstable
CSCux22620
8510 WLC crash in radiusTransportThread system task
CSCux28775
WLC per-WLAN client traffic stats accuracy enhancements
CSCux29207
Issue with SNMP GetBulk request -  cLAPGroupsHyperlocationEnable
CSCux32328
Token Bucket leak with QoS Roles and with WebAuth on 8.0.120.2
CSCux37498
CoA with wlc 8.1.131.0 shows error message on ISE server
CSCux41577
WLC and AP out of SYNC for Client Exclusion List
CSCux45077
AP3500 crashed due to "LWAPP CLIENT" process.
CSCux47470
8.0.110.14 controller crash at  openssl_cert_hash_algo_check_callback
CSCux51484
Memory leak observerd in EOGRE SNMP task
CSCux60012
With New Mobility - Mobility Members Don't survive reload
CSCux60873
Radius interface overwrite does not work when chosing "ap group" intf
CSCux65158
ATF : Globally configured mode not applied to newly joined APs
CSCux66190
No.of Interim Update Sent field is not flushing
CSCux69928
Wism2 Silent crash PMALLOC_DOUBLE_FREE on 8.0.122.18 MR3
CSCux74970
MAG w/PMIPv6 does not assign secondary DNS to clients via DHCP
CSCux75330
Mismatch AP count and unable to add more APs to WLC
CSCux78464
WLC crashes in Process Bonjour_Process_Task
CSCux81598
Memory Allocation problem with SAP1602
CSCux83260
BGL-Alpha: "lbs-ssc" &" sha256-lbs-ssc" missing in WLC web UI
CSCux83635
FATAL: Couldnt Send message out prints on 5500/7500 standby console
CSCux91996
Rogue containment not starting if no client info on best RSSI AP
CSCux92251
AIR-CAP2702 with WLC 8.2 doesnt allow HTTPS client access
CSCux93468
Anomalous Fan Speed/Temp reading for 8540
CSCux95607
ATF : User allowed to configure ATF on 1600 unsupported platform
CSCuy13829
AIR-CAP2602I crash on dot11_pmkid_timeout
CSCuy14547
HA Config Sync failed
CSCuy18768
Halo module doesn't work with RxSOP after image upgrade/dowgrade
CSCuy19485
Client detail table view miss alignment for a single client in bar graph
CSCuy21224
upport of 3G/4G module on 3600E/3700E APs
CSCuy23295
intf nasid given priority over wlan nasid in default Ap group
CSCuy33247
AP send disassociation frames twice and Optimized roaming go wrong
CSCuy37694
WLC crash running 8.0.120.0 at task apfRogueTask_1
CSCuy43365
5520 / 8540 8.2.100.0 Crash in Reaper Reset: Task "apfReceiveTask"
CSCuy45485
Containment to choose AP based on rogue client detected as well as RSSI
CSCuy45955
DFS scan causes beacon transmission to be stuck on AP
CSCuy47407
Client leak at anchor controller
CSCuy51343
Telnet/ssh config for AP is not retaining after upload/download config
CSCuy52607
Data Plane crash - cvmcs_StaToDS
CSCuy63742
Acct commands send inconsistently to TACACS server for rapid commands
CSCuy73622
Time sync failure for mmMsg_HandoffComplete on MC not printed on debugs
CSCuy92423
CWA broken in beta image 8.0.122.50
CSCuy94534
3700/2700 on DFS dont see 3700/2700 as neighbor when Rxsop High/Med/Low
CSCuy95327
802.1x frames are not marked with DSCP CS4
CSCuz01093
Traceback apf_site_override.c:2888 Invalid value 0 for WLAN
CSCuz02871
Webauth acl is not pushed from flexgroup when a new wlan is added to AP
CSCuz15763
Flex Data DTLS enabled AP gets stranded with WAN link flap
CSCuz22237
mobility express CORSICA: client not authenticated from 802.1x,wep)
CSCuz22985
BCAST Queue full causing Clients to stay Multicast-direct Pending status
CSCuz23758
Local Profiling Not Sorting Correctly, not corrected on 8.0.132
CSCuz24467
Mem corruption on GUI crash related to hreap avc group page
CSCuz38059
Anchor WLC does not free Client Sessions - client entries stale
CSCuz39100
ATF config not applied when no AP joined on controller
CSCuz46264
Flood of %SOCKET_TASK-7-DATA_PROCESSING_FAILED error messages
CSCuz47863
SHA256 self-signed cert for WLC web admin
CSCuz49616
WLAN-VLAN Mapping incorrect when AP moves across AP-Groups of diff WLANs
CSCuz52435
Evaluation of wlc for OpenSSL May 2016
CSCuz56009
Client reassoc not happening when central dhcp enabled
CSCuz56598
Enabling radio after disable/enable admin status,ifno channels available
CSCuz57198
SNMP AP3800:Clean air on xor radio is not functioning properly
CSCuz57392
AP3800 SNMP: Need errors for Channel Settings
CSCuz58908
AP3800 FRA configurations not retained in HA setup
CSCuz60033
WLC is dropping data packets in Hybrid VoWiFi setup
CSCuz63274
mDNS snooping drops IPv6 mDNS traffic
CSCuz67766
WLC crash due to software watchdog for apfMsConnTask_0
CSCuz68446
NOS: bsnAPIfTable has NULL entries
CSCuz69239
Flex local auth: 11n clients showing as 11ac
CSCuz70444
AP3800: XOR Microcell stuck on max power
CSCuz70999
AP3800: WLC crash while executing XOR radio commands
CSCuz71197
8500 wlc crash when starting 11v dms on sim clients
CSCuz72522
AP3800: FRA COF Metrics shows stale value for disabled Radios
CSCuz73422
1852 AP EAP-TLS client authentication fails
CSCuz73502
Spartan:2.4G data not shown for AP-Ch.Util,AP-Dist by SS,AP-Model Distr
CSCuz74209
AP3800: client network preference default is not default
CSCuz74637
WLC login banner does not show up on GUI. When using CLI it works fine.
CSCuz74989
AP3800: Issue setting channel for XOR radio in sniffer mode
CSCuz77060
SNMP:Radio Mode Trap generated when admin status changed for xor
CSCuz79051
WiSM2 8.1.131.0 crash in ewaFormServe_multicast_detail
CSCuz79869
8510 silent crash
CSCuz81176
AP3800: Beacons stuck seen in radio 0 & 1
CSCuz81415
1msec delay in processing IGMP packets causing Bcast queue to remain ful
CSCuz84096
RRM doesn't change channel for mesh APs in 8.1 and 8.2
CSCuz86679
5508 HA SSO crash on SNMPTask
CSCuz87680
WLC crashes with task:emweb on changing wlan config
CSCuz89491
BVI interface is down with latest recovery image
CSCuz89662
1852 Reject clients association due to "suppRates statusCode is 18"
CSCuz96571
Ap-list new mobility packets flooding between AirOS WLC
CSCuz97117
AP3800 CCO image "show inventory" displays incorrect SN & VID format
CSCva03344
Client capabilities shown as 160 MHZ even client is not 160MHZ
CSCva03888
3802 : DSCP marked as 0 in capwap header with CAC config
CSCva08910
Unable to view the client details by clicking on connection rate
CSCva09603
AP3800: 160 Mhz throws SNMP error
CSCva11172
No netflow records exported for anchored client in Auto Anchor Scenario
CSCva12198
SNMP get on device for table cld11nMcsTable returns only 24 indices
CSCva12984
DHCP_OPTION_43 functionality broken in AP3800 AP
CSCuz81074
ME3800: Upgrade failure from 8.2 mr1 to 8.3
Leo Laohoo Thu, 06/30/2016 - 16:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hope CSCux23003 will be addressed in this code.
I think it is, Rasika.  BST is showing Known Fixed Release as 8.2.113.3.
Javier Contreras Sat, 07/02/2016 - 22:51
  • Cisco Employee,
hi Ben
The fix is not yet ready, but we are working to see if it can be included (it only affects specific applications and flow types)
regards
patoberli Fri, 07/08/2016 - 06:50
  • Bronze, 100 points or more
Hi All
I'm having my "yearly" maintenance window in 3 weeks. I have planned to upgrade from 8.0.120.0 to 8.2.111.0, because I plan to get some 2802i in a few months.
Would you, in my situation, recommend me to directly go to this beta version (which has a very long list of fixed issues, also for the new AP series) or stick to the stable 8.2.111.0?
I could also do an upgrade at a later time, but by far better would be my normal maintenance window.
It's two 5508 controllers in a failover configuration.
Javier Contreras Mon, 07/11/2016 - 00:26
  • Cisco Employee,
if you plan to do 2800/3800, I would suggest to use current or next beta refresh to be published in the coming days. There are significant improvements for 8.2 branch that would be of great benefit vs using 111/110.0
Beta code has limited support (TAC would only support MR beta until CCO final code is published). if you need extended support  due to significant business reasons, please reach out to me to discuss possible solutions.
Our release target is for end of July, so we may be in time
regards
patoberli Mon, 07/11/2016 - 06:58
Thanks for your reply.
In case of a technical issue with the current beta release, I can make a special maintenance window :)
patoberli Tue, 07/26/2016 - 10:37
Installed today build 8.2.111.40. Upgraded from build 8.0.120.0. The upgrade took around 40 minutes for my SSO 5508 pair with 50 connected APs. I pre-downloaded the image to the APs which is not included in these 40 minutes.
All in all it took around 1 hour for the full upgrade. So far, after 10 minutes of testing, everything seems to be working. I use local mode APs of the models 3702i and 2702i.
nbankpedersen Tue, 07/12/2016 - 11:42
Sounds good - do you know if ME images will be available as well?
 - and is this the right place to ask about inclusion of bugfixes in beta images, specifically CSCuz29774, I've had an 1852 disconnecting from the master AP 4-8 times a day since I started testing them, and I suspect CSCuz29774 to be the culprit.
N.C.
Javier Contreras Wed, 07/13/2016 - 06:04
  • Cisco Employee,
hi
I just posted ME image, it is available on the download folder
You can direct bug questions directly to me
At this time, CSCuz29774 is not scheduled to be included in 8.2, but will be part of 8.3
regards
JEFFREY SESSLER Mon, 07/18/2016 - 18:19
Would CSCuz84305 impact the creation of heatmaps in Prime? i have a building that has nothing but 2802i WAPs, and while there is a heatmap generated/displayed for 5Ghz, there is no heatmap for the XOR radio (currently running in 2.4). In my office I have a 3800, and while the surrounding 3702's have heatmaps in 2.4 and 5, there is no heatmap for the 3800 XOR radio (running in 2.4.)
On the use of beta code for customers with 2800/3800 WAPs. Should I use/deploy the 8.2.110.10 as originaly suggested, or is it best to deploy the 8.2.11.30? I have a residential hall that is WiFi only and will be using the 3800's, so they have to work.
BTW - running 5508 on 8.2.110.0 and Prime is 3.1 MR1 (support for XOR radio).
hofmanm Tue, 07/19/2016 - 17:08
Although the list of bugs fixed in 8.2MR2 is pretty long the list of bugs fixed in 8.0MR3 and forthcoming on 8.0MR4 is even longer.
That raises of course question which of the bugs fixed in 8.0MR3/4 are also present in 8.2MR2 and are might not yet addressed? Is there some kind of "bug parity" list available? Would the release notes of 8.2MR2 still list those non addressed but present bugs as "known/open issues"?
hofmanm Wed, 07/20/2016 - 05:10
I guess that's of course an important point: the mentioned tool would be ok but only once the bug list would be entirely public visible (and bugs are properly associated with each release if affected or not). And of course it would be almost impossible to check for each bug individual in which release it is now fixed.
patoberli Wed, 07/20/2016 - 05:23
Absolutely true. On a positive note, if the bug affects several releases, it keeps the same BugID, so you could compare the release notes with each other.
Javier Contreras Tue, 08/16/2016 - 01:41
  • Cisco Employee,
Hi Ben
Currently, there are no plans for a 8.2MR3 release, with 8.3 as a target to move for long term support (future MD release)
That  said, if the two issues are critical for you, please ask TAC to escalate (or let me know your case number by private message), so my team can work with you on fixing them,  and delivering a 8.2MR2 based escalation image
regards
adwang_bing Wed, 08/24/2016 - 10:14
Does 8.2.121.0 also support the -B regulatory domain access points?  I know there is a note specifically calling out support for the -B regulatory domain support in the 8.2.111.0 release notes, but did not see that note in the 8.2.121.0 release notes.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
