06-30-2016 10:42 AM - edited 03-08-2019 06:26 AM
Hi ,
Can anyone tell me how to upgrade Cisco 6509 Supervisor WS-X6K-SUP2-2GE to VS-S720-10G-3C .
Existing Hardware detail is
NAME: "Chassis", DESCR: "Cisco Systems WS-C6509 9 slot switch" PID: WS-C6509 , VID: , SN: X.X.X.X.X.X.X
Switch > (enable) sh module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes ok
2 2 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
3 3 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
4 4 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
5 5 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
6 6 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
7 7 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
8 8 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
9 9 48 10/100BaseTX Ethernet WS-X6148-45AF yes ok
Solved! Go to Solution.
07-06-2016 12:35 PM
Hi James,
In this case you would have to upgrade the fan trays and the power supplies or it might be just easier to purchase a new 6509-E chassis.
Good Luck!
06-30-2016 11:47 AM
Is your chassis 6509 or 6509-E
All versions of Supervisor Engine 720-10GE require that a high-speed fan tray (either a fan tray 2 or Catalyst 6500-E series fan tray) be installed in the chassis.
Note Low-speed fan trays do not provide sufficient cooling for Supervisor Engine 720-10GE.
see link for more details:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/supe_gd/02superv.html#38465
07-06-2016 12:12 PM
Hi Reza,
Thanks for the reply ,
My Chasis is 6509 with catOS
BOOT variable = bootflash:cat6000-sup2k8.8-4-5.bin,1;bootflash:cat6000-sup2k8.7-5-1.bin,1;
WS-C6509 Software, Version NmpSW: 8.4(5)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Aug 3 2005, 12:01:19
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k8.8-4-5.bin'
Mod Sub-Type Sub-Model
1 L3 Switching Engine II WS-F6K-PFC2
2 IEEE InlinePower Module WS-F6K-FE48-AF
3 IEEE InlinePower Module WS-F6K-FE48-AF
4 IEEE InlinePower Module WS-F6K-FE48-AF
5 IEEE InlinePower Module WS-F6K-FE48-AF
6 IEEE InlinePower Module WS-F6K-FE48-AF
7 IEEE InlinePower Module WS-F6K-FE48-AF
8 IEEE InlinePower Module WS-F6K-FE48-AF
9 IEEE InlinePower Module WS-F6K-FE48-AF
07-06-2016 12:35 PM
Hi James,
Good Luck!
