07-01-2016 04:14 AM - edited 03-17-2019 07:25 AM
My production environment includes Cisco Unified Communication Manager Publisher and subscriber running version 10.5 and Cisco Unified Contact Center Express Publisher and Subscriber running version 10.6 SU2
The CUCM Pub and UCCX PUB are located in the HO, and the CUCM SUB and UCCX SUB are located on a remote site.
The two sites are connected via WAN connection (Microwave Link)
The problem is: the UCCX -SUB appadmin web interface is not responding where user cannot login to the its webpage.
User is able to Login to UCCX serviceability, Operating system, Disaster Recovery and reporting.
Please note that the UCCX publisher is working as desired.
Below you can find the troubleshooting one to solve the problem:
Any advice would be appreciated.
07-02-2016 09:06 AM
Be sure that the microwave link isn't dropping packets or exceeding the allowed RTT delay pee the UCCX SRND.
Assuming it is not a network problem and since you can get into CCX Servicibility are all of the services IN SERVICE on the sub? Are the datastores all active and in sync? Are CDS and HDS active?
Either way, a TAC case is probably your next stop.
07-11-2016 03:22 AM
The DB replication is good.Else i tired to restart the servers ( primary than secondary) with no luck to solve the issue.
All the UCCX services and components are up and running.
i will check the link satus before proceeding by the tac case.
thanks for your support.
07-11-2016 01:11 PM
Logon to the CCX Pub.
Goto System/Cisco Unified CM Configuration
In the Select Server drop down select the CCX Sub
See how your Your Selected AXL Service Providers are set.
I would have the UCM Sub first and the UCM Pub second
Also logon to your UCM and make sure the AXL web interface is running on both the Pub and Sub
Graham
07-04-2016 01:02 AM
Adding to what Jonathan said, please check the replication status as well using below commands:
utils uccx dbreplication status
util dbreplication runtimestate
Since you have not attempted a complete cluster reboot yet, hence I will strongly recommend to do that before involving TAC. First restart the primary UCCX server and once it comes up go ahead with the secondary server
Deepak
