ā07-04-2016 06:26 AM - edited ā03-10-2019 06:38 AM
Hi All,
I just need to confirm if Cisco Firepower Interfaces configured in inline group can be configured and paired as sub interfaces and then mapped to the zones or I need to map physical interfaces only for inline interfaces ?
Current : S1, S2 - > Inline Pair
Required : S1.1, S2.1 ( VLAN100) - > Inline Pair
Required : S1.2, S2.2 (VLAN 200) -> Inline Pair
My main objective is create access policies based on the specific VLAN rather than complete physical interfaces.
Thank you in advance.
Br,
Dhruv
ā07-04-2016 06:46 AM
Hi All,
I went through below link and it describes how we can create sub interfaces and how we could use them when configuring our IPS in route mode and transparent mode interfaces. But I want to configure them in Inline mode. Please help.
http://www.cisco.com/c/en/us/td/docs/security/firepower/601/configuration/guide/fpmc-config-guide-v601/fpmc-config-guide-v601_chapter_01101011.html#task_4FA3FC2F83774196A854661C2C85D434
Smart License |
Classic License |
Supported Devices |
Supported Domains |
Access |
Any |
N/A |
Firepower Threat Defense |
Any |
Access Admin |
VLAN subinterfaces let you divide a physical, redundant, or EtherChannel interface into multiple logical interfaces that are tagged with different VLAN IDs. An interface with one or more VLAN subinterfaces is automatically configured as an 802.1Q trunk. Because VLANs allow you to keep traffic separate on a given physical interface, you can increase the number of interfaces available to your network without adding additional physical interfaces or devices.
Preventing untagged packets on the physical interfaceāIf you use subinterfaces, you typically do not also want the physical interface to pass traffic, because the physical interface passes untagged packets. This property is also true for the active physical interface in a redundant interface pair and for EtherChannel links. Because the physical, redundant, or EtherChannel interface must be enabled for the subinterface to pass traffic, ensure that the physical, redundant, or EtherChannel interface does not pass traffic by not naming the interface. If you want to let the physical, redundant, or EtherChannel interface pass untagged packets, you can name the interface as usual.
Step 1 | Select Devices > Device Management and click the edit icon () for your Firepower Threat Defense device. The Interfaces tab is selected by default. |
Step 2 | Click Add Interfaces > Sub Interface. |
Step 3 | On the General tab, set the following parameters:
Step 4 | Click OK. |
Step 5 | Click Save.
You can now click Deploy and deploy the policy to assigned devices. The changes are not active until you deploy them. |
Step 6 | Configure the routed or transparent mode interface parameters. See Configure Routed Mode Interfaces or Configure Transparent Mode Interfaces. |
