Dial-Peer: show dialplan number
kozorezdi
Hello everyone,
R1#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
20001  pots  up   up             30022$             0                           50/0/1
20002  pots  up   up             3002$              0                           50/0/2
5      voip  up   up             2T                 0  syst ipv4:192.168.2.2
15     voip  up   up             2...               0  syst ipv4:192.168.2.2
R1#
dial-peer voice 5 voip
 destination-pattern 2T
 session protocol sipv2
 session target ipv4:192.168.2.2
dial-peer voice 15 voip
 destination-pattern 2...
R1#show dialplan number 2001 | in tag
    tag = 15, destination-pattern = `2...',
    voice reg type = 0, corresponding tag = 0,
    voice class perm tag = `'
R1#
R1#show dialplan number 2001# | in tag
    tag = 5, destination-pattern = `2T',
R1#
R1#sh call active voice | in PeerId
PeerId=20002
PeerId=15
R1#
Dial 2001 from 3002(sccp) - digit-by-digit or enblock(with #, call) - same result: always dial-peer 15.
It is logical to me: 1000 variants better than T, but... For enblock it knows the length, so both dial-peers looks the same.
1) Does the command "show dialplan number" work as enblock?
2) Why my case the active call is used dial-peer 15, but by the command the preferable is dial-peer 5?
Please clarify a little bit the situation, thank you in advance.
P.S. dial-peer hunt 0
Have a nice day,
Dmitry
Brandon Buffin
Dmitry,
Dial peer matching will choose the longest explicit match. In each case dial peer 15 is the longest match. The "show dialplan number" command is showing you a list of possible dial peers, not necessarily in order of preference.
Brandon
Hello Brandon, everyone,
Thank you very much for your comment.
I have checked the situation again and I was wrong - both dial-peers are used.
Now I have other questions, but it will be not correct to keep it under this discussion.
So I am going to open a new discussion about the selection of outgoing dial-peer. Anyway thank you for you message.
R1#show voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x3        11EE 0x31DB8858 50/0/2.0                 2002       g729r8   20002/5
1 active call found
0x9        1200 0x31DB8858 50/0/2.0                 2001       g729r8   20002/15
1 active call found
R1#show dialplan number 2001 timeout | in tag =
Have a nice day,
Dmitry
