Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919145members
1223243discussions
Community Activity
How do i get a human at American 𝐀𝐢𝐫𝐥𝐢𝐧𝐞𝐬 immediately?
혏혰호 혥혰 혐 혨혦혵 혢 혩혶혮혢혯 혢혵 혈혮혦혳혪혤혢혯 퐀퐢퐫퐥퐢퐧퐞퐬 혪혮혮혦혥혪혢혵혦혭혺?  혛혢혭혬 혵혰 혴혰혮혦혰혯혦 혰혯 혈혮혦혳혪혤혢혯 혈혪혳혭혪혯혦 혴혮혰혰혵혩혭혺, 혨혪혷혦 혵혩혦혪혳 혥혦혥혪혤혢혵혦혥 혴혶혱혱혰혳혵 혭혪혯혦 혢 혳혪혯혨 혢혵 +1-805-751-2794. 혛혢혬혦 혺혰혶혳 혵혪혮혦 혢혯혥 혭혪혴혵혦혯 혤혢혳혦혧혶혭혭혺 혵혰 혵혩혦 혢혶혵혰혮혢혵혦혥 혱혳혰혮혱혵혴, 혵혩혦혯 혴혩혢혳혦 혢혭혭 혵혩혦 혳혦혲혶혪혳...
lui35 by Level 1
  • 1 Views
  • 0 replies
How do i get a human at American 𝐀𝐢𝐫𝐥𝐢𝐧𝐞𝐬 immediately? Service
lui35 by Level 1
  • 1 Views
  • 0 replies
Cisco ISE, Meraki MX FWs and dynamic VLANS
Hi,Our network only consists of Meraki products and now we are looking at the possibility of implementing 802.1X on wired and using Cisco ISE for that.Our business is geographically very spread out and we have both large and small branches. Some smal...
sdkhy by Level 1
  • 19 Views
  • 1 replies
SMTP route to Email Public address
Hello community,  i have a question, but can`t find answer on it.  If we have one listener for inbound and outbound communication and this private IP has NAT to public IP. We don`t have communication to mail server on private IP.  Is it a problem if ...
FTD is getting licensing connectivity issues
My FTD (FDM) running code 7.2.5.1-29 is getting the following message on the Smart License section: CONNECTION ISSUEFailed To Connect With License Server Lost connection for 0 days (Next Sync on 28 Mar 2024 11:06 PM). Please check and make sure the m...
Nexus 5k vPC pair connecting to VxRail nodes
First I'll state i also have an open case with Vmware.  I inherited a vPC pair that had a number of vPC set up, but the multiple links to the VxRail host nodes were trunk links.  We lost the secondary so only the trunks to the primary vPC were up.  A...
FabricPath - 3 DCs in a ring
HiI'm working with a customer that has a Dual DC setup with 2 x Nexus 5600's in each DC in a vPC setup. These switches connects the two DCs together with 4 x 10G using FabricPath. The customer will leave one of the DCs and during the migration the ne...
9800-L WLC Controller and CA Signed Cert Web Server
Does anyone have a Cisco 9800-L WLC Controller and successful installed a CA Signed Cert for Web Server? Not making the Certificate signing request, but actually already have the PEM and other files locally. Cisco TAC can't figure it out. The documen...
classintr by Level 1
  • 59 Views
  • 1 replies
IPSEC issues with existing network
Hello I am working with a network that has currently 10 router nodes using IPSec tunneling to communicate and encrypt packets between the 10 router nodes over a wan. Using 140.0.0.0/30 (64 tunnels total) for IPSec Tunneling I have consumed almost all...
JNC3 by Level 1
  • 130 Views
  • 5 replies
Looking for snmp configuration for cisco N540x router
Hi All,Looking for snmp configuration for cisco N540x router.I got information in cisco docs.But configuration bit confuse.Can someone please send me actual command to configure snmp in cisco N540x routerThanks,Prashanth
Refreshing APIC-L2's with APIC-L4's
Hello all,I'm trying to make sure I understand the procedure for refreshing our current L2 APIC's with our new L4 APIC's.Currently our fabric is running 5.2(4) , and the new L4 APIC's require either 5.3 or 6.0.5 (which has just come out and is what w...
vv0bbLeS by Level 1
  • 52 Views
  • 1 replies
  • 1 Helpful votes
vpn missing route
Hi! Can you help me with troubleshoot, I don't know where I am wrong?I don't see on BUH2, route from BUH1 (81.1.210.0/24).I attached config from BUH1, BUH02, ClinicaA01, ClinicaB02, P0.
i_hanu by Level 1
  • 30 Views
  • 0 replies
RSP720-3C-GE in a CISCO7609-S chassis
I have no experience with this hardware and i can't get it to work. Booting an image lands me in rommon with the error message:Baseboard and rommon type mismatch. Rommon upgrade needed.%Software-forced reloadI switched over the MSFC4 to a RSP720-3C-1...
vermat51 by Level 1
  • 66 Views
  • 1 replies
