07-12-2016 08:35 AM - edited 03-05-2019 07:02 AM
We have a MPLS WAN where we are deploying SIP. Our datacenter(DC) has a 100Mb MPLS connection and most of our sites are at 1.5Mb but some are up to 20Mb. We are currently only applying QOS shaping on the egress port at each site including the DC. We are using a 4 queue template that is 20% EF, 20% Critical data, 20% bulk data and 40% best effort. We have looked at utilization on the current PRI links and we have some peaks above our current QoS settings. We are thinking of giving the Real-Time data queue 40% instead of 20% but that doesn't affect ingress traffic just egress.
My questions are:
07-12-2016 01:41 PM
You really need the MPLS provider to support QoS as well to make this work really well.
If a class has a guarantee of a certain size and you exceed it, then the excess traffic is simply not guaranteed but can still be delivered. It may have additional latency and almost certainly more jitter.
08-25-2016 10:08 AM
Hi Philip,
Sorry for the late reply.
We do use the carriers 4 que QOS model. It matches our egress qos settings 20(ef)/20(cd)/20(bd)/40(be).
Should we just increase que 1 for ef traffic to say 40% instead of 20%.
We are rolling out centralized SIP and migrating away from site specific voice PRI's. We don't wan't to lose SIP calls due to running over the 20% que.
I know there is a lot more to qos then I currently understand. I'm just trying to wrap my head around how real time traffic(VOIP) should be prioritized and why.
08-25-2016 12:12 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Unfortunately, you have provided enought information to answer your questions.
Is your topology hub-and-spoke or mutlipoint?
If hub-and-spoke, can the aggregate of the spokes overrun your hub?
How (precisely) do you implement your egress QoS at your sites?
How (precisely) does you MPLS vendor's QoS operate?
Your VoIP uses what codec?
10-12-2016 02:36 PM
Hi Joseph,
Sorry for the delay in my response.
We have a HUB and Spoke with multiple MPLS carriers and several MOE spoke sites.
Each of our MOE and MPLS carrier networks are full mesh.(See attached)
Individual MPLS networks aggregate could overrun our HUB. (See attached)
Here is our Egress QOS policy at a sample spoke site.
The Centurylink MPLS and MOE operate differently. The MPLS has 4 queues as does the MOE but with the MOE the P1 queue bandwidth is purchased in 5Mb increments the remaining are shaped. We then share the remaining BW P2 40% P3 20% P4 40%
The MPLS is also 4 shaped queues P1 40%, P2 20%, P3 20%, P4 20%. All queues can borrow from other queues if there is BW available from my understanding.
---------------------- MOE QOS -----------------------------------
class-map match-any Priority_1_QMOE
match ip dscp cs5 ef
match access-group name qos-priority1
class-map match-any Priority_2_QMOE
match ip dscp cs4 af41 af42 af43 cs6 cs7
match access-group name qos-priority2
class-map match-any Priority_3_QMOE
match ip dscp cs3 af31 af32 af33
match access-group name qos-priority3
policy-map OUTBOUND_QMOE
class Priority_1_QMOE
set ip dscp ef
priority 5000
class Priority_2_QMOE
set ip dscp cs4
bandwidth remaining percent 40
class Priority_3_QMOE
set ip dscp cs3
bandwidth remaining percent 20
class class-default
set ip dscp default
policy-map 20M_QMOE
class class-default
shape average 18000000
service-policy OUTBOUND_QMOE
interface FastEthernet0/1
description 20M_QMOE
ip address 172.19.10.10 255.255.255.0
service-policy output 20M_QMOE
------------------ MPLS QOS ---------------------
class-map match-any Priority_1_MPLS
class-map match-any Priority_2_MPLS
class-map match-any Priority_3_MPLS
match ip dscp cs3 af31 af32 af33 cs6 cs7
policy-map OUTBOUND_MPLS
class Priority_1_MPLS
priority percent 20
set dscp ef
class Priority_2_MPLS
bandwidth percent 20
set dscp cs4
class Priority_3_MPLS
set dscp cs3
class class-default
bandwidth percent 40
policy-map 1.5M_MPLS
class class-default
shape average 1350000
service-policy OUTBOUND_MPLS
interface Serial0/0/0:0
description Century Link MPLS Circuit DS1IT
ip address x.x.x.x 255.255.255.252
service-policy output 1.5M_MPLS
----------------- Shared QOS Access list -------------------------
ip access-list extended qos-priority1
remark ShoreTel call control
permit udp any any range 5440 5448
permit udp any any eq 2427
permit udp any any eq 2727
permit udp any any eq sunrpc
permit tcp any any eq sunrpc
permit tcp any any eq 5440
permit tcp any any eq 31453
permit udp any any eq 31453
remark ShoreTel call controll
permit ip host 192.168.1.221 any
permit ip host 192.168.1.220 any
permit ip any host 192.168.1.221
permit ip any host 192.168.1.220
ip access-list extended qos-priority2
permit tcp any any eq telnet
ip access-list extended qos-priority3
remark Move VDI and SSH to dedicated priority queue
permit tcp any any eq 22
permit ip host 192.168.10.68 any
permit ip any host 192.168.10.68
permit tcp any any eq 4172
permit udp any any eq 4172
We will be using G.711.
