SSHv2 - RSA Keys
zekebashi
Level 4
Level 4
I created a simple config file, listed below, and tried to copy and paste this config on a 2960-8Port switch. After pasting this file,  I receive as error message when I issue this command "show ip ssh SSH Disabled - version 1.99 % Please create RSA Keys to enable SSH (of at least 768 bits size) to enable SSH v2. Authentication timeout: 120 secs; Authentication retries: 3"
I can't figure out why ssh v2 won't enable. I've tried it on several boxes/switches but I still receive the same error message.
Any idea as why this happens.
Thanks in advance.
Best, ~zK
no service pad
hostname Sales-SW-ACC2
ip domain name my.company.come
boot-start-marker
boot-end-marker
enable secret 5 xoadou435o4nadgaet!%Aou2
no aaa-new-model
ip dhcp pool 10.0.0.0
    network 10.0.0.0 255.255.255.0
    lease 0 0 10
service dhcp
spanning-tree mode past
spanning-tree pordtfast default
vlan internal allocation policy ascending
crypto key generate rss generate-keys modulus 1024
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface vlan1
ip address 10.0.0.1 255.255.255.0
ip sea enabled reaction-alerts
ip dhcp excluded-address 10.0.0.1 10.0.0.10
line console 0
line vey 0 4
   privilege level 15
transport input telnet
line vty 5 15
no login
end
Milos Megis
Level 3
Level 3
you have command "crypto key generate RSS".
It should be "RSA".
This command also take some time, so it cannot be used in copy/paste (I had same problems with it).
Type it again.
On line vty you need to use transport input ssh or transport input all (for telnet and ssh).
Also SSH require use of username and password authentication.
So create at least one user with command username user privilege 15 secret password
