07-13-2016 03:07 AM - edited 03-17-2019 06:14 PM
this is my first Time here in CSC.
I hope you can help me :)
We use Jabber on Windows and now i have the following Request:
A User leave´s the Company. Now the new One need all the Contacts and Groups.
Is it possible to transfer the Jabber-Contacts from Client-to-Client? Is there an 3rd-Party Application availible?
best regards
Olli
Solved! Go to Solution.
07-13-2016 07:36 AM
Then you will need to get the info via CLI, and then create a .xml that you can provide your user to import directly in Jabber
http://docwiki.cisco.com/wiki/CUPS/IM%26P_FAQ#How_to_delete_all_contact_lists.3F.3F
07-13-2016 07:10 AM
IM&P -> Bulk Administration -> Contact List -> Export Contact List
Then use the update option to move them to the new user.
07-13-2016 07:23 AM
Hi Jaime,
thx for your Answer.
I followed your way and there is an error:
Begin Time : 07/13/2016 16:16:57
******** NO ERROR FOUND ********
Result Summary :
EXPORT for 0 Contacts passed.
EXPORT for 0 Contacts failed.
End Time : 07/13/2016 16:16:57
There are no sql results for this query
What i have to do now?
07-13-2016 07:28 AM
I just tested in my lab and it works fine, not sure what you're doing to get that.
I suggest you try a few different users and see the outcome.
07-13-2016 07:33 AM
Yes, thats right.
I made a test with my Account.
It exports only the internal Contacts not the external.
The User i need to export only have external Contacts.
07-13-2016 07:36 AM
10-26-2017 01:49 AM
Hey Jaime,
I tried to follow your instructions, but I am not aware of how I can create the xml file out of the sql statements, because all table output of the custom contacts are encrypted - any Idea?
René
08-27-2020 01:01 PM - edited 08-27-2020 01:02 PM
The link Jaime originally linked to was removed when Cisco retired docwiki, but a mirror of the original document can be found here. URL Below:
06-09-2021 07:24 AM
I need to export the external contacts for many users, but in the document I cannot find a CLI command the list the whole contacts for a user.
Can you help me?
Mirko
11-02-2018 03:05 AM
You can use Vcard Exporter Tool for exporting outlook contacts to Vcard without changing their content. I hope you will get the accurate results with this tool. The entire working of the tool seems to be simple.
For more details, visit on the given link – http://www.vcard-exporter.filefixutility.com/
