07-13-2016 05:23 AM
I have problem with configuring DHCP Snooping on SG220-50P. I find how to configure :
In page 210 is written how to configure, but on switch I dont have option to enable or disable DHCP snooping.
Version on switch: 1.0.0.19
Any idea?
BR
Klemen
07-14-2016 02:27 AM
Hello Klemen,
I made a test in the lab and found out that this feature is not present on the switch even though it is described in its Administration Guide.
I am really sorry for the inconvenience this might cause you.
What I can suggest is that you call our support line, so we can open up a case for that and escalate it.
You can find the corresponding phone number to reach us here:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Kind regards,
Milan Milanov
07-14-2016 06:00 AM
Hello Milan,
tnx for answer. But if I want open up a case for that I need Smartnet, I suppose ?
BR
Klemen
07-14-2016 06:07 AM
Hello Klemen,
If your device is under warranty you can open up a case with us without having a Smartnet contract.
Kind regards,
Milan Milanov
