Create more secure self-signed certificates on IOS router?
ROBERT HOLMES
I am running a 1921 router and use it partially as an AnyConnect (WebVPN) server for remote access into the location.  The certificate I used was a self-signed certificate & trustpoint generated on the router.  I am running the latest IOS track available to insure it has all the newest capabilities.
Doing a quick SSL check against it from Qualys, it appears to have many known vulnerabilities and weaknesses.
* Poodle TLS
* TLS 1.0 only
* SHA1
* Diffie-Hellman 1024 bit
* Some older ciphers that appear to be available (but I never specified), like TLS RC4_128_MD5
The crypto mechanism and commands to create the cert didn't give me much choice in the matter.
Is there a newer/better way to create a more secure certificate chain on an IOS router?  I couldn't find the instructions anywhere.
Robert
2 Accepted Solutions
Philip D'Ath
Have a look at my guide for doing Suite-B VPNs.  It creates much more secure certificates.  Note my comment about the minimum software version to use.
https://www.ifm.net.nz/cookbooks/Cisco-IOS-router-IKEv2-AnyConnect-Suite-B-Crypto.html
No you don't.  It is only the certificate portion that is relevant to your question.
5 Replies 5
Philip D'Ath
Very interesting, thanks!
Do you require IKEv2 using this method?  I need the ability to do split-tunneling.
OK, trying this now and looking it over.  It seems to be way more involved that what I was expecting.  Isn't there a way to just have it use a reliable cert (AES-256, SHA256, etc) without having to create a unique cert for each client?  This will be used by a variety of clients that I don't want to pre-load a cert for, from iPhone's to PC's.
Thanks.
If you only want a certificate for the router that is secure - then only generate a certificate for the router.  You don't need to generate certificates for users if they don't need them.
