07-20-2016 10:38 AM - edited 03-12-2019 01:02 AM
I'm getting an error when trying to direct HTTPS to a specific IP.
object network HTTPS
host 10.10.100.11
nat (inside,outside) static interface service tcp 443 443
ERROR: NAT unable to reserve ports
I do have AnyConnect VPN setup using SSL (FYI). I'm a bit new to cisco. I'm more of a self leaner. Please help. Thanks
Solved! Go to Solution.
07-20-2016 12:56 PM
Hello Fabian,
I hope you are fine, the ASA is unable to reserve the ports, because port 443 is already in use by either ASDM if you have it enabled or for your vpn connections, for that reason the firewall is unable to assign port 443 to your host.
You can however change the mapping port for external connections to another port, 4443 for example.
host 10.10.100.11
nat (inside,outside) static interface service tcp 443 4443
When your outside host try to reach the internal host, remember to type in the web browser the following:
Https://x.x.x.x:4443 where x.x.x.x is the public ip of your internal host
Please note that when the packet arrives to the ASA he will translate port 4443 to 443, which is the port that your internal host is listening to.
Hope this helps!
Kornelia Gutierrez
07-20-2016 12:56 PM
Hello Fabian,
host 10.10.100.11
Hope this helps!
Kornelia Gutierrez
07-20-2016 01:10 PM
Very well explained. Thx!!!
