Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929029members
1243020discussions
Community Activity
How can I get in touch with Singapore 𝔸irlines? 24* Hours Service
How Can I Speak to a Singapore 픸핚핣핝핚핟핖핤 Representative Fast?  【Singapore Guide 헙헮혀혁 & 헙혂헿헶헼혂혀】 Talk to someone on Singapore 픸핚핣핝핚핟핖 smoothly, give their dedicated support line a ring at + ퟭ-ퟖퟖퟖ ✈ ퟖퟐퟗ ✈ 1316 . Take your time and listen carefully to t...
How do I Talk to someone On Singapore 𝔸irlines? 24 Hours Service
How do I connect to Singapore 𝔸irlines? 24 Hours Service
Fix empty startup-config for C9200L
For Cisco WS-C9200L-24T-4G-E, a user tried to backup configuration from Web portal. But did wrongly that uploaded empty text file to the device.That is:Copy to devicetftpaaa.txt (created from local computer)startup-configupload to device.Now the star...
Pleox by Level 1
  • 16 Views
  • 2 replies
Site-to-site vpn failover causing memory spike in spoke sites
Hi All. I would like to get your thoughts on the following issue i have been facing since implementing Dual ISP and failover for site-to-site vpn tunnels.Hub Site:ASA5515 using 9.6(4)42Spoke sites:Cisco ISRs using 15.1(4)M8, using voip services over ...
PikaPika by Level 1
  • 105 Views
  • 6 replies
Cisco Switch Web UI with HTTPS (lock icon)?
Hello, has anyone successfully implemented HTTPS on their switch web management UI? I would like to get rid of the warning when I access the web UI, but I cannot seem to find resources about it online.I am currently using a Catalyst 9300 in my networ...
Mitel - DHCP Discovery
Hi, I have a Mitel 5312 phone plugged into a switchport configured for ISE but when it boots up it gets stuck on DHCP Discovery. If I put the port to authentication open then it goes through and boots up as normal.The logs all look ok but I can't see...
Joining ISE on a Reversed DNS Zone
I have joined ISE on the same reversed zone as 50.168.192.in-addr.arpa (ise1.srvcore.local), but ISE have an address of 192.168.99.35.ISE could resolve and ping DNS domaine names on Windows Server and could PING its name "ise1.srvcore.local" and can ...
Jason2005 by Level 1
  • 11 Views
  • 0 replies
cant wr or copy run start
hi all,before on this switch (nexus 7000) i could do a "wr" or "copy run start" no problem but now i get thiswr[########################################] 100%Configuration update aborted: request was abortedthanks,rob
Cat9200/9200L 製品の Stack 構成において、管理ポートから不正な MAC をもつパケットを送信する場合がある
2024年4月24日 (初版) TAC SR Collection主な問題 Catalyst 9200 / 9200L シリーズの Stack 構成において、Active な管理ポート ( EMP : Ethernet Management Port ) が、Active role の機器上のものではない場合、管理ポートより不適切な MAC アドレスをもつパケットを送信する場合があり、接続先の機器にて不要な MAC アドレスの登録されることがあります。管理ポートからは適切な MAC アドレ...
Cat9200 シリーズにおいて、show inventory の表示が "Unknown Uplink Module" となる
2024年4月24日 (初版) TAC SR Collection主な問題 Cat9200 シリーズにおいて機器を再起動した際に、show inventory で出力される Uplink module の Description 表示が、"Unknown Uplink Module" となる場合があります。表示上の問題となり、ご使用上の影響はございません。 Switch#show inventory NAME: "Switch 1", DESCR: "C9200-48T" PID: C...
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 338 Views
  • 14 replies
C9500 Stackwise-virtual failover BGP downtime
Hello,we have deployed pair of 9500-32C in Stacwise-virtual. It is Aggregation node of big site and connecting to backbone by 2 EBGP links (one from each switch).I have noticed long downtime during ISSU and as we are deploying more of these to other ...
ms339r001 by Level 1
  • 69 Views
  • 2 replies
