PFR ROUTING
Amit kumar
we have two Internet circuits from two different ISPs. But inbalance of inbound traffic load balancing has been happening between the two circuits.
The circuit from ISP-A is fully utilized at around 80%, while the other from ISP-B is at around less than 20%.
We want to try to equalize the two circuit utilization for inbound traffic as much as possible. And I think PfR might work.
But since this is the 1st consideration of PfR for me, I’d wanted to help from you guys , so every thing can go smooth, most important , devices are in production.so applying any policy or changes would be on consideration.
Now my questions are:
is ISP would play the most important role , or it can be done only through ISP only, they need to advertise these Ip's for inbound traffic load balancing.
  1. Does our design work to mitigate our issue? I am planning to use “PfR - Inbound Load Balancing” referring to the below links. My concern is that our local global subnet to be advertized to eBGP is only one(202.xx.xx.x/24) so prepending AS number might/might not work.
  2. i am referring these documents.
http://docwiki.cisco.com/wiki/PfR:Solutions:InternetInboundLoadBalancing
http://www.cisco.com/c/en/us/td/docs/ios/pfr/configuration/guide/15_1/pfr_15_1_book/pfr-bgp-inbound.pdf
  1. Is our design fine for PfR in the point of adding one MC and only running EIGRP to have reachability to L3SW and Internet routers?
  2. Our routers have only IPBase feature. Do we need DATA license for all three routers (current Internet routers Model: Cisco 3925 )
  3. What happens if primary router is stuck due to any reason(such as lack of CPU/Memory resource)?
The prefix controlled by PfR is just controlled by normal routing?
0 Replies 0
