07-26-2016 02:23 PM
It seems when you upgrade from Windows 7 to Windows 10, the Cisco VPN Client Version 5.0.07.0290 gets removed, with error saying incompatibility.
Looking forward to a fix.
07-26-2016 07:27 PM
The Cisco VPN Client has reached End-of-Support status, and will be removed from the Cisco.com Support site in July 2016. All previous releases (versions 3.x through 4.x) have officially been retired as of August 2015. All software downloads for Cisco VPN Client Series (all releases) have also been retired from Cisco.com.
It is recommended that users upgrade to next-generation Cisco AnyConnect Secure Mobility Client v4.xwhich supports 64-bit (x64) Windows and Windows 10.
http://www.cisco.com/c/en/us/support/security/vpn-client/tsd-products-support-eol-series-home.html
However i found this third party link that has a woraround to fix the VPN client:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-services-tech/1127-cisco-vpn-client-windows-10-install-fix-442-failed-to-enable-virtual-adapter.html
Aditya
Please rate helpful posts and mark correct answers.
07-26-2016 08:01 PM
Luke
