07-27-2016 05:50 AM - edited 03-07-2019 12:17 AM
I have a question regarding the hardware compatibility of the C6840-X-LE-40G.
We would like to use the QSFP Ports as 4 x10G Ports, is it possible to use the QSFP-4X10G-LR-S with that box?
Many thanks for your feedback
Adrian
07-27-2016 06:40 AM
According the matrix below is not supported:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/40GE_Tx_Matrix.html#_Toc455034907
HTH.
