07-27-2016 08:16 AM - edited 03-10-2019 11:57 PM
Hi there, can a single ISE node support PAN/PSN/TACACS+?
Please advise
07-27-2016 08:29 AM
Yes, all services can run on the same ise node
07-27-2016 08:38 AM
Thanks for the quick response,
Also Do we have any document/article/blog supporting this feature?
Please provide if you can...sir
07-28-2016 09:56 AM
I don't think so, it's just a design choice you make...usually based on your network size and amount of devices/users. Normally you would not run everything on one ISE node, but you can if you want to.
