07-28-2016 01:10 PM - edited 03-17-2019 07:40 AM
Hello
We just got few cisco 7841 phone. We want to use them with asterix. I tried to flash the firmware sip78xx.10-3-1-11-3PCC.loads but it's not working.
This is the error in the message file on the web .
Could please somebody help me, or let me know how to get this work?
currently the firmware is
App Load ID | rootfs78xx.11-5-1-18 | |
Boot Load ID | sboot78xx.11-5-1-18 | |
Version | sip78xx.11-5-1-18 |
1133 NOT Jul 28 20:01:56.014954 (1382:1382) TFTPD-pid = 1382 1134 NOT Jul 28 20:01:56.044010 (1382:1382) TFTPD-LIMIT downdload will be limited to 2048 KB 1135 ERR Jul 28 20:01:56.045994 (1382:1382) TFTPD-ai_family = 2, sockType = 2, protocol = 17 1136 NOT Jul 28 20:01:56.049198 (1382:1382) TFTPD-Requesting sip78xx.10-3-1-11-3PCC.loads from 10.250.246.69 1137 WRN Jul 28 20:01:56.049687 (1382:1382) TFTPD-sendto() failed : Address family not supported by protocol 1138 NOT Jul 28 20:01:56.528246 (523:909) JAVA-set gTOS = 0, ret=0, sock=40 1139 NOT Jul 28 20:01:56.528429 (523:909) JAVA-then get tos = 0, socket=40 1140 NOT Jul 28 20:01:56.528643 (523:909) JAVA-set gTOS = 0, ret=0, sock=42 1141 NOT Jul 28 20:01:56.528734 (523:909) JAVA-then get tos = 0, socket=42 1142 NOT Jul 28 20:01:56.552418 (1382:1382) TFTPD-Timeout: retransmit the last packet (1) 1143 NOT Jul 28 20:01:56.557973 (1382:1382) TFTPD-Finished: rcvd 988 bytes 1144 NOT Jul 28 20:01:56.567190 (1360:1360) dgetimage-FORCED-TFTP complete - status = 0 1145 NOT Jul 28 20:01:56.578361 (1360:1360) dgetimage-GETIMG AUTH RAM FILE 1146 ERR Jul 28 20:01:56.578849 (1360:1360) dgetimage-sec_validate_image_file 1147 ERR Jul 28 20:01:56.580253 (1360:1360) dgetimage-sec_validate_image_file Cisco header size (340) 1148 ERR Jul 28 20:01:56.596337 (1360:1360) dgetimage-IMGAUTH_ERROR Verification Failure 1149 NOT Jul 28 20:01:56.603631 (1360:1360) dgetimage-astat = -12, realfname=sip78xx.10-3-1-11-3PCC.loads, buf->offset=0 1150 NOT Jul 28 20:01:56.608515 (1360:1360) dgetimage-GETIMG-DEBUG auth astat:[-12], VFY_SUCCESS:0 1151 NOT Jul 28 20:01:56.608972 (1360:1360) dgetimage-GETIMG: astat: -12, buf->status:244, VFY_SUCCESS:0 1152 NOT Jul 28 20:01:56.609400 (1360:1360) dgetimage-GETIMG: returned with 244 1153 NOT Jul 28 20:01:56.610560 (1347:1347) img-nopfs-&&&done dd_get_image_ replies 244 1154 ERR Jul 28 20:01:56.610743 (1347:1347) img-nopfs-LOAD6 [offset:-244] downdload image file failure. 1155 NOT Jul 28 20:01:56.706546 (1360:1360) dgetimage-DDGETIMG.RESULT [Error description unknown]
07-28-2016 03:14 PM
This error message tells me the firmware is corrupt.
Try downloading the standard SIP files (in ZIP) and use that.
07-28-2016 11:39 PM
Hi Leo
I download the firmware directly from https://software.cisco.com/download/release.html?mdfid=284892536&reltype=all&relind=AVAILABLE&dwnld=true&softwareid=282074288&rellifecycle=&atcFlag=N&release=10.3(1.11)%203rd%20Party&dwldImageGuid=B736B51892800CD791E9F71A5B9953FF41112FA4&flowid=46503
and unzipped it to the tftp directory.
It was working for firmware 11 and also for 11.5 but 10.3 for third party is not working. I do not know how otherwise setup the phone to be used with asterisk.
07-29-2016 12:22 AM
Search in this forum. I've already helped a few people how to do this.
07-29-2016 12:31 AM
thanks I will do so , hovewer can we please go back to the issue with the firmware? Is there any way of help?
thank you
07-29-2016 12:49 AM
Same as before. I've helped some people with this too.
You will need the following:
1. The firmware of the phone (ZIP file);
2. SEPmacaddress.xml.cnf;
3. DHCP Option 150; and
4. TFTP server
07-29-2016 01:01 AM
|I have all this.
I downloaded the firmware and unzipped it.
I setup the tftp ip address manually on the phone to my tftp server.
I created the XMLDefault.cnf.xml
<Default>
<loadInformation622 model="Cisco 7841">sip78xx.10-3-1-11-3PCC</loadInformation622>
<webAccess>1</webAccess>
<sshAccess>1</sshAccess>
<sshPort>22</sshPort>
</Default>
the firmware is download from cisco website and uzipped. but wont gets loaded
07-29-2016 01:13 AM
The phone version is 10.X. XMLDefault.cnf.xml will NOT be used. I repeat:
4. TFTP server
07-29-2016 01:13 AM
the phone version is currently 11.5 not 10.x XMLdefault.cnf.xml is used as I can see that in the tcpdump that it's requesting this file and downloading as well.
07-29-2016 02:19 AM
Hi Here is the tcpdump
there is clearly written it's getting the xml file. also on the phone I see that the upgrade failed. but I do not know why.
02:23:35.525481 IP 10.250.246.200.52667 > 10.250.246.69.tftp: 27 RRQ "XMLDefault.cnf.xml" octet
02:23:35.525960 IP 10.250.246.69.11952 > 10.250.246.200.52667: UDP, length 199
02:23:35.527193 IP 10.250.246.200.52667 > 10.250.246.69.11952: UDP, length 4
02:23:38.723787 IP 10.250.246.200.50819 > 10.250.246.69.6970: Flags [S], seq 2472810909, win 29200, options [mss 1460,sackOK,TS val 4294957051 ecr 0,nop,wscale 4], length 0
02:23:38.723804 IP 10.250.246.69.6970 > 10.250.246.200.50819: Flags [R.], seq 0, ack 2472810910, win 0, length 0
02:23:39.317007 IP 10.250.246.200.51739 > 10.250.246.69.tftp: 37 RRQ "sip78xx.10-3-1-11-3PCC.loads" octet
02:23:39.317547 IP 10.250.246.69.11952 > 10.250.246.200.51739: UDP, length 516
02:23:39.319192 IP 10.250.246.200.51739 > 10.250.246.69.11952: UDP, length 4
02:23:39.319276 IP 10.250.246.69.11952 > 10.250.246.200.51739: UDP, length 480
02:23:39.320309 IP 10.250.246.200.51739 > 10.250.246.69.11952: UDP, length 4
02:23:39.999861 IP 10.250.246.200.52157 > 10.250.246.69.tftp: 37 RRQ "sip78xx.10-3-1-11-3PCC.loads" octet
02:23:40.000474 IP 10.250.246.69.11952 > 10.250.246.200.52157: UDP, length 516
02:23:40.001338 IP 10.250.246.200.52157 > 10.250.246.69.11952: UDP, length 4
02:23:40.001379 IP 10.250.246.69.11952 > 10.250.246.200.52157: UDP, length 480
02:23:40.002126 IP 10.250.246.200.52157 > 10.250.246.69.11952: UDP, length 4
