08-01-2016 03:34 PM
Hello All guys,
Hope this post finds you well. I was going over some Inter-AS multicast VPN and at this point im really stuck. I know the final goal its to have a PIM neighbor up for a particular VRF (between PEs), so you can forwards PIM join messages between both AS-s.
I started with a big topology and in order to simplify it and to get to understand how it works, i have reduced it to a few boxes:
AS1 (same for AS2):
3 CSR1000v + 1 IOS XRv
CSR1000v as PE router and another for RR, then 2 ASBRs CSR1000v and an IOS XRv.
Both AS have the same physical topology, connected to one CE each.
I had L3VPN inter AS option B working perfect with end to end connectivity working just fine.
Then on top of that, i wanted to add support for Multicast VPN (Just Rosen-GRE). I read in one of the multicast VPN configuration guides, that you need to configure the VRF aware ip multicast-routing command in the ASBR when you are using Inter AS option B (i guess just to enable the mdt address command) and also when using a IOS XR as an ASBR you need to enable support for PIM-vector.
Here below, are the configuration for the 2 PEs, both ASBRs (one XE and one XR) and the RR (just included one as both have identical configurations but different IP addressing):
PE-AS100
vrf definition CUST
rd 100:1
address-family ipv4
mdt default 232.0.0.1
mdt data 232.0.1.0 0.0.0.255
route-target export 100:1
route-target import 100:1
exit-address-family
address-family ipv6
exit-address-family
ip multicast-routing distributed
ip multicast-routing vrf CUST distributed
ip multicast vrf CUST rpf proxy rd vector
ipv6 unicast-routing
interface Loopback0
ip address 100.0.0.2 255.255.255.255
ip pim sparse-mode
ip ospf 100 area 0
ipv6 address 2001:100::2/128
interface GigabitEthernet2
ip address 100.0.0.17 255.255.255.252
ip pim sparse-mode
ip ospf 100 area 0
negotiation auto
ipv6 address 2001:100::17/127
interface GigabitEthernet5
vrf forwarding CUST
ip address 100.0.0.30 255.255.255.252
negotiation auto
ipv6 address 2001:100::30/127
router ospf 100
router-id 100.0.0.2
passive-interface Loopback0
mpls ldp autoconfig
router bgp 100
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 100.0.0.3 remote-as 100
neighbor 100.0.0.3 update-source Loopback0
neighbor 100.0.0.29 remote-as 400
address-family ipv4
exit-address-family
address-family vpnv4
neighbor 100.0.0.3 activate
neighbor 100.0.0.3 send-community extended
exit-address-family
address-family ipv4 mdt
neighbor 100.0.0.3 next-hop-self
exit-address-family
address-family ipv4 vrf CUST
neighbor 100.0.0.29 activate
exit-address-family
ip forward-protocol nd
ip pim ssm default
mpls ldp router-id Loopback0
line con 0
exec-timeout 0 0
logging synchronous
transport preferred none
stopbits 1
line vty 0 4
no login
end
PE-AS200
vrf definition CUST
rd 100:1
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no ip domain lookup
interface Loopback0
ip address 200.0.0.2 255.255.255.255
ip pim sparse-mode
ipv6 address 2001:200::2/128
ip address 200.0.0.14 255.255.255.252
ip pim sparse-mode
ip router isis 200
negotiation auto
ipv6 address 2001:100::14/127
vrf forwarding CUST
ip address 200.0.0.45 255.255.255.252
negotiation auto
ipv6 address 2001:200::45/127
router isis 200
net 49.0000.0000.0000.0002.00
is-type level-2-only
metric-style wide
mpls ldp autoconfig
router bgp 200
neighbor 200.0.0.3 remote-as 200
neighbor 200.0.0.3 update-source Loopback0
address-family ipv4
exit-address-family
neighbor 200.0.0.3 activate
neighbor 200.0.0.3 send-community extended
exit-address-family
neighbor 200.0.0.3 next-hop-self
exit-address-family
neighbor 200.0.0.46 remote-as 300
neighbor 200.0.0.46 activate
exit-address-family
ip pim ssm default
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line vty 0 4
no login
end
ASBR-AS100
vrf definition CUST
rd 100:1
address-family ipv4
exit-address-family
interface Loopback0
ip address 100.0.0.1 255.255.255.255
ip pim sparse-mode
ip ospf 100 area 0
ipv6 address 2001:100::1/128
ip address 100.0.0.18 255.255.255.252
ip pim sparse-mode
ip ospf 100 area 0
negotiation auto
ipv6 address 2001:100::18/127
interface GigabitEthernet6
ip address 100.0.0.61 255.255.255.252
ip pim sparse-mode
negotiation auto
ipv6 address 2001:100::61/127
mpls bgp forwarding
router ospf 100
router-id 100.0.0.1
mpls ldp autoconfig
router bgp 100
no bgp default route-target filter
neighbor 100.0.0.62 remote-as 200
address-family ipv4
exit-address-family
neighbor 100.0.0.62 activate
neighbor 100.0.0.62 send-community extended
exit-address-family
exit-address-family
ip pim ssm default
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line vty 0 4
no login
end
ASBR-AS200
vrf CUST
address-family ipv4 unicast
address-family ipv6 unicast
line console
exec-timeout 0 0
interface Loopback0
ipv4 address 200.0.0.4 255.255.255.255
ipv6 address 2001:200::4/128
interface GigabitEthernet0/0/0/0
ipv4 address 200.0.0.13 255.255.255.252
ipv6 address 2001:200::13/127
interface GigabitEthernet0/0/0/1
ipv4 address 200.0.0.53 255.255.255.252
ipv6 address 2001:200::53/127
interface GigabitEthernet0/0/0/2
ipv4 address 200.0.0.25 255.255.255.252
ipv6 address 2001:200::25/127
interface GigabitEthernet0/0/0/3
ipv4 address 100.0.0.62 255.255.255.252
ipv6 address 2001:100::62/127
route-policy PASS
pass
end-policy
route-policy rpf-for-cust
set core-tree pim-default
end-policy
router static
100.0.0.61/32 GigabitEthernet0/0/0/3
router isis 200
net 49.0000.0000.0000.0004.00
metric-style wide
mpls ldp auto-config
interface Loopback0
passive
router bgp 200
address-family vpnv4 unicast
retain route-target all
neighbor 200.0.0.3
remote-as 200
next-hop-self
next-hop-self
neighbor 100.0.0.61
remote-as 100
route-policy PASS in
route-policy PASS out
vrf CUST
rd 100:1
mpls ldp
router-id 200.0.0.4
multicast-routing
address-family ipv4
interface Loopback0
enable
enable
enable
enable
enable
mdt source Loopback0
vrf CUST
address-family ipv4
mdt default ipv4 232.0.0.1
mdt data 232.0.1.0/24
router pim
address-family ipv4
rpf-vector
interface Loopback0
enable
enable
enable
enable
enable
vrf CUST
address-family ipv4
rpf topology route-policy rpf-for-cust
end
I know i have some mixed concepts in the configuration above (maybe at this point im kind of dizzy), but i know that this should work something like this:
PIM neighbor has to come up between both PEs in both ASs. for tha tto happen i need to have unicast routing for L3VPN inter AS Option b working properly already (which is).
Then to add PEs to support ssm on the VRF (configure MDT default), to enable multicast routing vrf aware, to generate the PIM vector and to enable MP-BGP support for MDT SAFI with the RR and in the inter AS link along with VPNV4. For ASBR to recognize PIM vector, enable upport for it under router pim. VRF addition to ASBRs i did it later on in order to see if the problem was that even the MTI was comming up on each individual AS, there was no intra AS PIM neighbor yet (and still none).
Thanks in advance for your time.
