08-02-2016 01:11 PM
I am testing XRv in my lab environment and I have this topology:
CSR1<-gi2.112->---eBGP---<-gi0.112->XR2<------iBGP----->XR1
There is Lo0 adresses:
CSR1 - 10.0.0.11
XR2 - 10.0.0.2
XR1 - 10.0.0.1
I have established eBGP session between CSR1 and XR2, there CSR1's AS is 65100, and XR2's AS is 100. I use BGP LU (AFI 1 SAFI 4) and advertise Lo0 addresses into BGP via network statement.
XR2 config:
router bgp 100
bgp unsafe-ebgp-policy
address-family ipv4 unicast
network 10.0.0.2/32
allocate-label all
neighbor 10.0.0.11
remote-as 65100
ignore-connected-check
update-source Loopback0
address-family ipv4 labeled-unicast
send-community-ebgp
send-extended-community-ebgp
neighbor 10.0.0.1
remote-as 100
next-hop-self
interface Loopback0
ipv4 address 10.0.0.2 255.255.255.255
router static
10.0.0.11/32 GigabitEthernet0/0/0/0.112 10.1.112.11
CSR1 config:
ip route 10.0.0.2 255.255.255.255 GigabitEthernet2.112 10.1.112.2
router bgp 65100
template peer-policy core_transport
send-community both
send-label
exit-peer-policy
bgp log-neighbor-changes
neighbor 10.0.0.2 remote-as 100
neighbor 10.0.0.2 disable-connected-check
neighbor 10.0.0.2 update-source Loopback0
address-family ipv4
network 10.0.0.11 mask 255.255.255.255
network 10.0.1.11 mask 255.255.255.255
neighbor 10.0.0.2 activate
neighbor 10.0.0.2 inherit peer-policy core_transport
interface Loopback0
ip address 10.0.0.11 255.255.255.255
interface GigabitEthernet2.112
description "to_XR2_Gi0/0/0/0.112"
encapsulation dot1Q 112
ip address 10.1.112.11 255.255.255.0
mpls bgp forwarding
everything is working fine except the fact that XR2 does not allocate local label for 10.0.0.11 and does not advertise prefix 10.0.0.11 to XR1:
RP/0/0/CPU0:XRv2#show bgp ipv4 labeled-unicast labels
Network Next Hop Rcvd Label Local Label
*>i10.0.0.1/32 10.0.0.1 3 24018
*> 10.0.0.2/32 0.0.0.0 nolabel 3
*> 10.0.0.11/32 10.0.0.11 3 nolabel
*> 10.0.1.11/32 10.0.0.11 3 24031
RP/0/0/CPU0:XRv2#show bgp ipv4 labeled-unicast 10.0.0.11
BGP routing table entry for 10.0.0.11/32
Versions:
Process bRIB/RIB SendTblVer
Speaker 114 114
Last Modified: Aug 2 19:29:18.158 for 00:14:21
Paths: (1 available, best #1)
Not advertised to any peer
Path #1: Received by speaker 0
65100
10.0.0.11 from 10.0.0.11 (10.0.1.11)
Received Label 3
Origin IGP, metric 0, localpref 100, valid, external, best, group-best
Received Path ID 0, Local Path ID 1, version 114
Origin-AS validity: not-found
RP/0/0/CPU0:XRv2# show bgp ipv4 labeled-unicast summary
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down St/PfxRcd
10.0.0.1 0 100 3583 3455 120 0 0 06:09:36 2
10.0.0.11 0 65100 112 117 120 0 0 00:38:40 3
During debug I have observed this output:
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr] (ip4lu): Received UPDATE from 10.0.0.11 with attributes:
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr] (ip4lu): nexthop 10.0.0.11/32, origin i, metric 0, path 65100
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr] (ip4lu): Received prefix 10.0.0.11/32 (path ID: none) with MPLS label 3 from neighbor 10.0.0.11
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: Received UPDATE from 10.0.0.11 (length incl. header = 63)
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: Receive message dump for 10.0.0.11:
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: ffff ffff ffff ffff ffff ffff ffff ffff
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: 003f 0200 0000 2880 0e11 0001 0404 0a00
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: 000b 0038 0000 310a 0000 0b40 0101 0040
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: 0206 0201 0000 fe4c 8004 0400 0000 00
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: Received UPDATE from 10.0.0.11 (length incl. header = 23)
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr]: 0017 0200 0000 00
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-rtr] (l2vpls): Wake up sync/rib thread ( afi 10), label version 1, rib version 1, bgp table version 1, standby ver 0
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-lbl] (ip4u): Label update triggered: current version 23, target version 24, mpls component is up
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-impt] (ip4u): START import walk from 23 to 24 skip_walk 1
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-upd] (l2vpls): Started updgrp timer for updgrp 0.1:: delay=0.010, delaytype=0
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-upd] VRF PAG (ip4u): Started updgrp timer for updgrp 0.1:: delay=0.010, delaytype=0
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-upd] (vpn4u): Started updgrp timer for updgrp 0.1:: delay=0.010, delaytype=0
RP/0/0/CPU0:Aug 2 13:47:46.806 : bgp[1052]: [default-upd] (vpn6u): Started updgrp timer for updgrp 0.2:: delay=0.010, delaytype=0
RP/0/0/CPU0:Aug 2 13:47:46.816 : bgp[1052]: [default-lbl] (ip4u): Label computation done: table=TBL:default (1/1), net=10.0.0.11/32: netfl=0x04002001, path=0x10fa5ef4(10.0.0.11/32,10.0.0.11,0,0x4000000001060001), pathrcvdlabel=3: asbr=1, rr=0/0, nhselfcount=1: result="label not required"
So far I have tryed:
-mpls activate for gi0/0/0/0.112 on XR2 - no help
-ignore-connected-check change to ebgp-multihop 2 - no help
-use different variations of static routes toward 10.0.0.11 on XR2 - no help
-use LDP to exchange label bindings for CSR1' and XR2' loopback on eBGP link - no help
-create another one ebgp neighbor on XR2 toward another one node - no help
-create peering using IP addresse of physical interfaces - works fine
-If I change the AS of CSR1 to AS100 and build iBGP session between CR1 and XR2 then XR2 starts to allocate the label for 10.0.0.11. But for eBGP no label allocation happens on XR2
-redistribute static route toward 10.0.0.11 on XR2 into BGP - works strange, look below:
XR2config:
router bgp 100
redistribute static
*>i10.0.0.3/32 10.0.0.3 3 24019
*> 10.0.0.11/32 10.1.112.11 nolabel 24004
* 10.0.0.11 3 24004
RP/0/0/CPU0:XRv2#show mpls forwarding labels 24004 detail
Tue Aug 2 19:53:38.083 UTC
Local Outgoing Prefix Outgoing Next Hop Bytes
Label Label or ID Interface Switched
24004 Pop 10.0.0.11/32 Gi0/0/0/0.112 10.1.112.11 25446
Updated: Aug 2 17:29:00.868
Version: 752, Priority: 4
Label Stack (Top -> Bottom): { Imp-Null }
NHID: 0x0, Encap-ID: N/A, Path idx: 0, Backup path idx: 0, Weight: 0
MAC/Encaps: 18/18, MTU: 1500
Packets Switched: 479
Versions:
Speaker 119 119
Local Label: 24004
Last Modified: Aug 2 19:51:16.158 for 00:02:51
Paths: (2 available, best #1)
Advertised to update-groups (with more than one peer):
0.2
Advertised to peers (in unique update groups):
10.0.0.1
0.2
10.0.0.1
Local
10.1.112.11 from 0.0.0.0 (10.0.0.2)
Origin incomplete, metric 0, localpref 100, weight 32768, valid, redistributed, best, group-best
Received Path ID 0, Local Path ID 1, version 119
Path #2: Received by speaker 0
65100
Received Label 3
Origin IGP, metric 0, localpref 100, valid, external, group-best
Received Path ID 0, Local Path ID 0, version 0
RP/0/0/CPU0:XRv2#
Is there any ideas to explain such a behavior (I have not found anything about this on CCO) and any workaround except of static route redistributin. Redistribution is not a good option for me as the locally originated route suppresses the eBGP route from CSR1 and if CSR1 assign some community to its route, this communities will not be propagated further by XR2 as it is reoreginates the route by itself.
08-03-2016 02:33 PM
Hi Denis,
Glad to see you )
What differences on CSR1`s side and XR2`s side between prefixes 10.0.0.11/32 and 10.0.1.11/32 while first one have no local label on XR2 and second one - have?
And why you want to have eBGP LU-session right between Loopbacks while over the physical interfaces all works fine?
08-03-2016 09:05 PM
Hi Olev,
The difference between the 10.0.0.11 and 10.0.1.11 is the fact that the first one is used as the source address for BGP session on CSR1 and as a BGP peer address on XR1, otherwise there is no difference.
Regarding second question - There is actually redundant path between loopbacks (not shown in the topology) and I want to use this path to preserve BGP session state between loopbaacks while the main path will fail. Also, I want to use this redundant path fow load sharing.
01-18-2017 12:18 PM
Hi Denis,
Sorry for off topic. I can see that you are using XRv. I am trying to deploy XRv 9k as well. I followed Cisco's "how to access console" no luck so far. Would you mind to take a look at here?
https://supportforums.cisco.com/discussion/13204506/console-connection-xrv-9k
Thanks in advance!
01-12-2020 11:16 PM
Did you try to change the AD of static route to 250?
