08-03-2016 12:03 AM - edited 03-21-2019 08:58 AM
i am using BE6k solution so for this can we add multiple extensions on single cisco phone? and single extensions on two ip phone?
Solved! Go to Solution.
08-04-2016 12:59 PM
Phone Model |
Number of Lines |
Cisco 7821 |
2 Lines |
Cisco 7940G |
2 Lines |
Cisco 7960G |
6 Lines |
Cisco 7970 |
8 Lines |
08-03-2016 02:30 PM
I hope that makes sense and is helpful.
08-04-2016 12:39 AM
Hi Luke Oxley,
Thanks for your reply.
please can you give example which are cisco multi-line phone.
and when we configure multiple extensions on this phone and can this phone get ring on any extensions.
can you provide the procedure how to perform this.
08-04-2016 12:59 PM
Phone Model |
Number of Lines |
Cisco 7821 |
2 Lines |
Cisco 7940G |
2 Lines |
Cisco 7960G |
6 Lines |
Cisco 7970 |
8 Lines |
08-04-2016 10:17 PM
Yes I wish to configure multiple extensions on one phone ..what is the best way to do it?
Multi-line phone get ring on any extensions that configured on that it is not like one extension is active other will be in standby mode right?
08-04-2016 10:52 PM
08-05-2016 01:04 AM
yes,I want to statically assign extensions.
statically assigning extension means phone can get ring on both extensions in active manner . am i right?
08-12-2016 10:54 AM
01-25-2017 01:02 AM
its not showing up on my 7962 ip phone after configuring second line though it says registered on cucm
