How to wipe VTP MD5 hash information?
Hello Cisco Support Community--I have this topology:
(Actually, 1 and 2 and 3 and 4 are connected with two parallel links--one is a Port Channel and the other is a regular Gig E).  Here's what I want to do:
Create a two VTP domains, with one VLAN in each domain.  Make SW1 the server for one VTP domain and SW3 the server for the other domain.  Make SW2 and SW4 clients of both domains.  Observe the behavior of both client and server switches when you make changes to the VLAN.
I started by configuring everyone into a bogus domain (BOGUS) and making them transparent in order to wipe the revision number back to 0.  Then I configured SW1 as the server for DRAZI-green domain and created VLAN 2 named GREEN. (Confirmed with sh vlan).  I initially chose version 3 and configured a password also.  When I went to configure SW2, it wouldn't support version 3, so I configured SW2 as a client in DRAZI-green using version 2.  Since I had a version mismatch, I issued no vtp password on both SW1 and SW2.  (I had initially configured a password on SW2.)  And I went back and re-configged SW1 to use version 2.  This is the what I'm getting.
SW1(config)#do sh vtp stat
VTP Version capable            : 1 to 3
VTP version running            : 2
VTP Domain Name                : DRAZI-green
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                      : 0019.55e5.3d80
Configuration last modified by 172.16.0.10 at 3-1-93 00:49:22
Local updater ID is 172.16.0.10 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally  : 1005
Number of existing VLANs          : 12
Configuration Revision            : 0
MD5 digest                        : 0x71 0xAB 0x85 0xC4 0x5B 0x74 0xCA 0xD5
                                    0xB5 0x10 0xF3 0xE3 0x6E 0xB6 0x71 0xFB
SW2(config)#do sh vtp stat
VTP Version                    : running VTP2
Number of existing VLANs        : 11
VTP Operating Mode              : Client
VTP V2 Mode                    : Enabled
MD5 digest                      : 0xF0 0xEC 0xA3 0x3A 0x3C 0x55 0xDA 0x37
*** MD5 digest checksum mismatch on trunk: Po1 ***
*** MD5 digest checksum mismatch on trunk: Gi1/0/3 ***
Configuration last modified by 172.16.0.20 at 3-1-93 06:03:21
I'm getting an MD5 checksum mismatch on the two links between SW1 and SW2, and SW2 has not synced information about VLAN 2 GREEN.  I've gone through all the VTP troubleshooting steps from both the SWITCH OCG and the TSHOOT OCG with no love.
I'm going to guess that the fact that my MD5 hashes don't match are causing a problem, even though neither SW1 nor SW2 are configured with a password.  Does anyone know how to clear the MD5 information from VTP?  I've tried switching SW2 from transparent mode to client mode, and switching domain from bogus back to DRAZI-green without success.  I've also deleted the vlan.dat file and reloaded SW2.  Also without success.
Thanks in advance!  Any thoughts would be greatly appreciated.  MM
Hello
The easiest and quickest way would be to delete the vlan.dat file from flash and reboot however its not that simple if this is a production environment.
res
Paul
Kind Regards
Paul
Rolf Fischer
Level 9
Level 9
the switches do not synchronize because the configuration revision is 0 on both. In order to synchronize, one configuration revision has to be higher ("more up-to-date") than the other. You could simply change the name of one VLAN on the VTP server (or just any change which increases the configuration revision) in order to force a synchronization; the mismatch should disappear then immediately.
Rolf
P.S.:
How can the clients be member of two different VTP domains?
thank you, that was my issue
