How to record a video on MX300
ledaivuong1990
I'm using Mx300 for video conference, but I don't know how to record a video on this device
My scenario:
- Record a HD video (720 - 1080) with sound
- Save this video on my laptop which connect with Mx300
Thank all for your time,
Vuong Le
You're not able to connect your laptop and use the endpoint's camera and microphone to record a video, it doesn't work like that and isn't capable of it, as the endpoint is used for the purpose of having video conferences.
Besides the TCS, you could use WebEx Meeting Center and CMR Cloud with the MX300 to record a video and save it to your computer.
5 Replies 5
Patrick Sparkman
TelePresence Content Server is the solution for recording video conferences involving endpoints or even conference bridges such as an MCU or TelePresence Server.  You connect to it just as you would any typical H323 or SIP participant, and you're capable of recording video, audio, and presentation content.
If you have more questions regarding this or how it would work, suggest you move this thread to the TelePresence section of the forums where these devices are actively discussed.  You can move the thread by editing it, and changing the categories at the bottom of the page.
[@patrick.sparkman]
Grateful for your help
Actually I don't need to recording video conferences, i just need to recording a simple video that the same way when you record a video on Mobile or other camera.
The problem:
- how to use the camera and mic on Mx300 to record?
- how to save the video to my laptop?
Thank you very much!
I don't get exactly what I must to do but I will try to find tutorial on page that you have provided
Best regards,
Vuong Le
Basically with both solutions mentioned above, you'd be creating a video conference by connecting the MX300 as a participant which would allow you to record the conference.
