08-05-2016 09:25 AM - edited 03-08-2019 06:53 AM
Hello friends,
I have 3 distribution switches - here is the output from one of them that has been showing up in the logs since the software upgrade and reload of the switch.
My question is why all of a sudden I'm getting these IGMP querier messages on my Distribution switch 1, but not on distribution switch 2 and 3?
*May 29 17:22:50 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 6 because PIM has been enabled on the SVI.
*May 29 17:22:57 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 7 because PIM has been enabled on the SVI.
*May 29 17:22:58 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 8 because PIM has been enabled on the SVI.
*May 29 17:22:59 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 9 because PIM has been enabled on the SVI.
*May 29 17:23:15 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 10 because PIM is no longer enabled on the SVI.
*May 29 17:23:16 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 11 because PIM is no longer enabled on the SVI.
*May 29 17:23:17 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 30 because PIM is no longer enabled on the SVI.
*May 29 17:23:19 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 9 because PIM is no longer enabled on the SVI.
*May 29 17:23:19 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 8 because PIM has been enabled on the SVI.
*May 29 17:23:22 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 10 because PIM has been enabled on the SVI.
*May 29 17:23:23 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 11 because PIM has been enabled on the SVI.
*May 29 17:23:25 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 30 because PIM has been enabled on the SVI.
*May 29 17:23:26 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 9 because PIM has been enabled on the SVI.
*May 29 17:23:36 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 18 because PIM has been enabled on the SVI.
*May 29 17:23:37 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 54 because PIM has been enabled on the SVI.
May 29 17:24:14 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 25 because PIM has been enabled on the SVI.
May 29 18:05:06 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 48 because PIM is no longer enabled on the SVI.
May 29 18:05:07 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 44 because PIM is no longer enabled on the SVI.
May 29 18:05:11 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 10 because PIM is no longer enabled on the SVI.
May 29 18:10:48 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 42 because PIM has been enabled on the SVI.
May 29 18:10:54 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 10 because PIM has been enabled on the SVI.
May 29 18:11:00 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 9 because PIM has been enabled on the SVI.
May 29 18:11:04 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 14 because PIM has been enabled on the SVI.
May 29 18:11:25 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 12 because PIM has been enabled on the SVI.
May 31 17:05:05 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 21 because PIM is no longer enabled on the SVI.
May 31 17:05:07 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 13 because PIM is no longer enabled on the SVI.
May 31 17:05:08 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 8 because PIM is no longer enabled on the SVI.
May 31 17:10:36 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 15 because PIM has been enabled on the SVI.
May 31 17:10:47 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 16 because PIM has been enabled on the SVI.
May 31 17:11:06 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 7 because PIM has been enabled on the SVI.
May 31 17:11:09 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 18 because PIM has been enabled on the SVI.
May 31 17:27:52 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 30 because PIM has been enabled on the SVI.
May 31 17:27:55 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 21 because PIM has been enabled on the SVI.
May 31 17:28:24 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 8 because PIM has been enabled on the SVI.
May 31 17:28:36 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 13 because PIM has been enabled on the SVI.
May 31 19:45:05 pdt: %IGMP_QUERIER-6-PIM_DISABLED: The IGMP querier is now operationally enabled in VLAN 41 because PIM is no longer enabled on the SVI.
May 31 19:49:43 pdt: %IGMP_QUERIER-4-PIM_ENABLED: The IGMP querier is operationally disabled in VLAN 41 because PIM has been enabled on the SVI.
08-05-2016 09:44 AM
Is IGMP supposed to be enabled on all these vlans? If yes, you may want to reconfigure your IGMP and PIM again and see if the problem disappears. You also may want to look at the release note for caveats and bug fixes for the version you are running.
08-05-2016 09:47 AM
How can I check to see if IGMP is enabled on these vlans? or all other vlans around my other distrbution switch svi's?
08-05-2016 09:49 AM
"sh ip igmp snooping" will show you what vlans have IGMP enabled.
08-05-2016 09:53 AM
This is what it looks like for every VLAN on all distribution switches
IGMP snooping : Enabled
IGMPv2 immediate leave : Disabled
Explicit host tracking : Enabled
Multicast router learning mode : pim-dvmrp
CGMP interoperability mode : IGMP_ONLY
Last member query interval : 1000
Vlan 9:
