08-08-2016 11:06 PM - edited 03-12-2019 01:06 AM
Hi Folks,
Is it secure to opening the UDP ports range (50,000 - 65,000) for VOIP on the firewall from the outside for video conferencing?
Saeed
Solved! Go to Solution.
08-16-2016 11:17 PM
Hi Bro
If it's required that those wide range of UDP ports be opened, then you’ve no choice but to do it. I personally don’t like this, but I’ve been in your shoes before.
However, I wouldn’t worry much because by default, you’ve these settings enabled in your Cisco FW;
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
However, it’s best that you harden your Cisco ASA FW with the other features available such as threat detection as shown below;
threat-detection basic-threat
threat-detection scanning-threat shun except ip-address 10.10.173.0 255.255.255.252
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
Lastly, there are other features you can enable as well such as Reverse-Path Forwarding, Multi Framework Policy i.e. class-map / policy-map for your UDP traffic etc.
Good luck sir!
Please do check-out some configuration notes below;
1. https://www.petenetlive.com/KB/Article/0001111
2. https://supportforums.cisco.com/discussion/11208446/port-range-forwarding-post-83-asa
08-10-2016 11:48 AM
You can open the ports though just take in count the security measures such as creating granular and specific rules matching only the necessary source and destinations
08-16-2016 01:00 PM
Hello Saeedullah. I have a couple of questions for you:
1. Do you have a set of outside IPs that you are looking to open this to?
2. Are you looking to open these ports to an individual internal IP? Like a VCS or MCU type device
Thank you for rating helpful posts!
08-16-2016 11:17 PM
Hi Bro
Good luck sir!
