Can we enable DHCP snooping on a single switch network?
Srikanth89
I am not quite fond of layer 2 security features as they appear to be simple and easy to understand rather than to implement.
Kindly help me on a layer 2 security query,
We have a single switch network:
External
FW
Core switch
Inside network with DHCP server
Is it advisable to configure dhcp snooping on a single switch network which also acts as a core switch for the network?
Also please advise how do we configure the same?
johnd2310
Level 8
Level 8
DHCP snooping is normally configured on access switches where clients connect. Do you have clients connected to the Core switch?
John
**Please rate posts you find helpful**
Hi John,
Thanks for the reply.
Yes we have clients and IP phones connecting to the same switch. It is a one switch network.
We have a DHCP server configured in the inside, so I just configure the "trusted config" on just that port?
Yes, you can configure dhcp snooping for your clients. I would also recommend configuring arp inspection and port security as well.
Before you configure dhcp snooping and arp inspection, check the ios version on your swicth. I have had some issues with dhcp snooping and arp inspection on 15.0 versions  of ios. 15.0.2.SE9 work fine. I haven't test the newer 15.0.2.SE10
Have a look at the following doc on configuration of dhcp snooping:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/SAFE_RG/SAFE_rg/chap8.html
John
