Cant log into Web UI Data Center Network Manager 10.0 (1)
rcurtiss1
The install guide says this...
After the Open Virtual Appliance is deployed, a Deployment Completed Successfully message appears.
Step 3 On the Summary tab in the vSphere Client, review the information about the VM and make note of the IP address.
Step 4 Check the console of the VM in the vSphere Client for the login prompt. Once the login prompt appears, log in with root credentials and use the appmgr status all command to check the status of the applications. After all applications are up and running, go to the next step.
Note For more information about verifying application status see the Verifying the Application Status after Deployment.
Step 5 Log in to the Cisco DCNM web UI:
a. Put the IP address in your browser.
The Cisco Data Center Network Manager window is displayed.
b. In the User Name field, enter admin.
c. In the Password field, enter the administrative password given to you during the DCNM Open Virtual Appliance deployment.
No such password was given? It will not allow me to log in as root either. (n the webui)
I can access root and log into it just fine in SSH
Walter Dey
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/dcnm/installation/master_files/OVA_Installation_Guide/installing_DCNM_OVA.html
b. In the Management Properties section, enter a password in the Enter Password and Confirm Password boxes to establish the password that will be used to connect all applications in the DCNM OVA.
The only password it ask for is the root password for the Centos. There is no option anywhere to add or change the password for the WebUI
