Export of Current Firmware on Devices
magnum629
Level 4
Level 4
I did not see an option under exporting phone details, and I am looking for a report that lists all the devices with the firmware that is currently loaded on each of them.  Running CUCM 9.1.2.  Thanks!
Deepak Rawat
You can run show risdb query phone on all the CM servers in the cluster to which phones are registered and then sort out the output in MS Excel and find the active FW load
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118307-probsol-cucm-00.html
Deepak
5 Replies 5
Mohammed Khan
"show tech devdefaults"  command will provide phone firmware defined in CUCM.
"show risdb query phone" command will provide phone firmware loaded on the phone.
Mohammed Noor
[+5] to Khan for sharing the command "show tech devdefaults" regds, aman
Aman Soi
hi ,
check this discussion
https://supportforums.cisco.com/discussion/12012036/how-know-firmware-version-all-devices-cucm-cluster
regds,
aman
Deepak Rawat
Deepak
magnum629
Level 4
Level 4
Thank you everyone!
