08-15-2016 12:44 PM
Hi All,
We have 3 x 2504 wireless controllers in 3 locations.
is there a product that can centrally manage them all ? whats the best practice for large organizations in multiple locations ?
Thanks.
08-15-2016 01:40 PM
tal0000011,
Based on the url under Management Interfaces, Cisco Wireless Control System(WCS) can be used to manage the WLCs that you have.
http://www.cisco.com/c/en/us/products/collateral/wireless/2500-series-wireless-controllers/data_sheet_c78-645111.html
HTH,
***Please rate and mark the comment correct if you find it helpful.***
08-22-2016 03:07 AM
is there a WCS version that runs on something newer then windows 2003 ?
08-15-2016 06:08 PM
Cisco Prime infrastructure is the replacement for the product WCS and you'll find it here,Which is the Cisco Wireless and wired network management solution.
There are different product from other vendors like solar wind that you can take a look.
Prabath
08-21-2016 01:44 AM
Thanks! installed prime and learning it now.. it looks very robust.
i've been trying to get some pricing information from cisco with no luck.. any idea what the pricing model is ? we only have about 10 devices, 3 controllers and 6 APs in 3 locations.
08-21-2016 07:59 PM
