08-15-2016 02:55 PM - edited 03-17-2019 07:50 AM
Hello All,
CallManager: v10.5(2)
I have a Cisco IP Phone 7962 with about 3 or 4 DNs configured on it. The first line on the phone is my Main line in which I have a voicemail box configured for in Unity Connection.
My 3rd line is my DID line so I can be reached directly from external callers... So what I was hoping to find out was, is it possible to have missed callers of my DID line (*or any other line for that matter) be sent to my Voicemail Box of my Main line?
Any thoughts or suggestions would be greatly appreciated!
Thanks in Advance,
Matt
Solved! Go to Solution.
08-15-2016 03:34 PM
If those DNs do not have their own mailbox, you can simply configure them as alternate extensions in the main line mailbox.
08-15-2016 03:34 PM
08-15-2016 11:46 PM
In addition you need to set the Service Parameter 'Message Waiting Lamp Policy' to 'Light and Prompt' in order to get MWI indication when the call is forwarded from non-primary line.
08-16-2016 07:57 AM
Hi Matt,
Let's say the user has numbers 7005,8450 & 7777 but we want only one mailbox @ 7005. There are a couple of ways to do this.
In CUCM go to> Feature> Voicemail> Voicemail Profile and create a new Profile called XXXX (whatever name you want) with a Description called "XXXX username Mailbox" the Voice Mail Box Mask will be 7005> Save
Then via CUCM go to the Users Phones> under Directory Number Config for 8450> Voicemail Profile and change to XXXX (created previously in above steps)>Update>Reset
Then apply the same Voicemail profile to 7777 and any other numbers you want to tie to the main mailbox @ 7005
Now when calls route via forward to Unity Connection from 8450 or 7777 they will reach the Mailbox @ 7005.
Or in Unity Connection set up Alternate Extension so that 8450 is an Alternate Extension for 7005 etc. as Java nicely noted (+5)
Cheers!
Rob
08-16-2016 10:23 AM
Hey Guys,
Thank you all for the replies, very much appreciated!! Lots of great ideas.
Ok, so it sounds like the Alternate Extensions setting in Unity might be the easiest method to try first. So I'll give that a shot and I'll post back shortly...
Thanks Again,
Matt
08-16-2016 10:38 AM
Ok, Perfect! The Alternate Extensions was exactly what I was looking for....
Thanks AGAIN guys for the help, very much appreciated!
Matt
