08-16-2016 10:06 PM - edited 03-10-2019 12:42 AM
Hi All,
My some of the Cisco device not sending the logs even after i adding this (Some device sending the logs)
Please let me know do we have to add anything else
x.x.x.x is the syslog server
logging host x.x.x.x
logging trap 7
Suneelkumar
08-17-2016 12:02 AM
That can have different reasons:
08-17-2016 12:20 AM
all the devices having logging on but enable option is not there
its proper source as i am able to ping the syslog from the switch
yes the syslog server is PRTG and there is no port blocking
Suneelkumar
05-03-2017 01:58 AM
Hello, Wish I am not too late.
So what you can try, is to synchronize your clock with an unique NTP server ( and choose the same for your PRTG ) It's really important. The first time I implemented Syslog i got this problem.
But right now i have another issue, while implementing syslog in HSRP environement, it works fine for the first switch, but when i do the same for the second PRTG doesn't receive any message??? I am stuck with this.
Wish my contribution helped you....
