08-17-2016 04:49 AM - edited 03-12-2019 01:08 AM
Hello there!
I have a question regarding upgrade path on Cisco ASA 5555.
I have an two ASA 5555 in Active/Standby running version 9.1(5) and I would like to upgrade them to 9.4(2), so I took a look at this document : http://www.cisco.com/c/en/us/td/docs/security/asa/asa94/upgrade/upgrade94.html
And it's written that for version 9.1(2) and later I can upgrade to 9.1(3), how should I understand this? This is mistake on the document? Do you think that I can directly upgrade to my target version?
Thanks a lot for your help,
Kevin
Solved! Go to Solution.
08-17-2016 05:12 AM
If you are at least on 9.1(2), you can upgrade to any 9.1(3) or higher release. That includes your desired release 9.4(2).
08-17-2016 05:12 AM
08-17-2016 05:18 AM
Thanks a lot for your prompt reply :)
Kevin
