08-17-2016 07:03 AM - edited 03-01-2019 05:01 AM
I do have all the infrastructure like NTP, DHCP, DNS and vCenter (for VMM integration) behind an shared L3ExtOut that is configured within the common tenant. So far we're using the L3ExtOut for connectivity from user tenants successfully, so everything is working nicely there.
What is the best approach to enable connectivity from the mgmt tenant to the L3ExtOut from the common tenant? Is it enough to attach the L3ExtOut profile to the inb's VRFs L3 Out association or are there some extra steps involved? I would also want the APIC to reach the vCenter server for VMM integration via the same L3ExtOut.
best,
P
08-17-2016 07:17 AM
Petar,
I am a traditionalist and I try to separate management traffic separate from fabric traffic. I use a separate L3out in the Tenant Management and the "int" VRF in tenant management. This separates management traffic from the fabric data from the external networks. If you share an L3Out in Common the L3Out is most likely in a common VRF. Hence, now you have to Route leak between VRFs. Do you really want to do this for management traffic?
If you want to proceed with the configuration that you mentioned above, you will not to make sure the contracts are configured between tenants and the route leaking is working as desired.
Cheers!
T.
08-17-2016 07:24 AM
So it basically works like it would do for any other subnet, right? I don't see any subnet being present with in the mgmt tenant. I can configure an IP policy, but do I need to create a matching subnet first?
08-17-2016 07:58 AM
You create the INBAND infrastructure just like any other "Network" in the Fabric.
ie.
VRF -> inb
BD -> inb
Node MGMT EPG -> In-Band default
