tracereroute fragmentation
burhanburhan
Hi all,
Is there any way to understand if fragmentation happening or not by traceroute command ?
Mark Malone
standard traceroute just shows latency in hops and what ips your passing , tracepath in Linux is one that can show you fragmentation , so below if I got reduced along path it would show beside the ms and state at the end the mtu , but below shows it hasn't been reduced anywhere along path
xxxxxxxxxxx:~$ tracepath -n 172.21.229.65
 1?: [LOCALHOST]                                         pmtu 1500
 1:  172.22.160.252                                        0.505ms
 1:  172.22.160.252                                        0.460ms
 2:  172.22.253.5                                          0.573ms
 3:  172.22.251.6                                          2.555ms
 4:  172.22.254.62                                         2.783ms
 5:  172.22.254.244                                        0.728ms
 6:  x.x.x.x                                           2.652ms
 7:  x.x.x.x                                          207.948ms asymm 19
 8:  172.21.254.254                                      210.249ms asymm 17
 9:  172.21.254.41                                       210.915ms asymm 17
10:  172.21.253.5                                        208.501ms reached
     Resume: pmtu 1500 hops 10 back 17
and is there a command to see this output at cisco routers ? or windows pc ?
if you doing it form cisco you can test the lowest path through ping in cli using ping .. size and then keep dropping size until you find the lowest mtu on path between src-dst that's useable
mturoute for windows should do the same
http://www.elifulkerson.com/projects/mturoute.php
Ok thank you Mark.
