08-18-2016 01:34 AM - edited 03-12-2019 01:08 AM
team,
I have a new cisco asa firepower 5515X.
I am not able to do configurations in firepower.
How to check asa firepower is installed or not?
ciscoasa# show module sfr
Mod Card Type Model Serial No.
sfr FirePOWER Services Software Module ASA5515 FCH2004797U
Mod MAC Address Range Hw Version Fw Version Sw Version
sfr 00c8.8bd3.979f to 00c8.8bd3.979f N/A N/A 5.3.1-152
Mod SSM Application Name Status SSM Application Version
sfr ASA FirePOWER Up 5.3.1-152
Mod Status Data Plane Status Compatibility
sfr Up Up
CAN ANY ONE HELP??
Solved! Go to Solution.
08-18-2016 04:13 AM
Hello Team,
Looks like the sfr is up .
Have you completed the installation using the following link ?
http://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html
If so, how you going to manage the firepower module ? Is it via ASDM or a Firesight Management Center ?
What kind of configurations that you are referring to ?
Jetsy
08-18-2016 06:44 AM
Hello Team,
Do you have a Firesight Mangement Center with connectivity with this ASA firepower. If so use that device as an ssh server and copy the file. But FTP should work as we tried this several times in our own lab. Make sure that teh connectivity is fine with the FTP and device that youa re trying to upgrade.
Rate and correct if the post helps you
Jetsy
08-18-2016 04:13 AM
Hello Team,
Jetsy
08-18-2016 04:35 AM
Jesty,
thanks for update.
Let me complete and update you
08-18-2016 06:26 AM
hello team,
i am not able to upload pkg file from ftp server.
76 packets transmitted, 0 packets received, 100% packet loss
asasfr-boot>
asasfr-boot>system install ftp://172.16.0.22/asasfr-sys-5.3.1-155.pkg
Verifying
111
Upgrade aborted.
Can any one help??
08-18-2016 06:44 AM
Hello Team,
Jetsy
08-18-2016 09:48 PM
Dear Jetsy,
Thanks for update...
Uploaded pkg file to asa.
Redirect Traffic to the SFR Module is not done
How can i check firepower is installed properly..??
I dont have firesight management.Can firepower configured and managed on box.Asdm still missing firepower configuration tab..
Kindly reply if possible...
