08-22-2016 06:42 AM - edited 03-08-2019 07:06 AM
We have a CME router Cisco 2951. We bought another one to act as backup. I've copied most of the config from Primary CME to Backup CME. For some reason I can't create interface VLAN(SVI) on the Backup CME. They have similar iOS and hardware (except ISM module) so not sure what is the diference.
Primary CME 2951
CMEGW-01#show ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.5(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 20-Jun-16 16:16 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
CMEGW-01 uptime is 5 weeks, 4 days, 20 hours, 51 minutes
System restarted at 17:36:00 gmt Wed Jul 13 2016
System image file is "flash:c2951-universalk9-mz.SPA.155-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Cisco CISCO2951/K9 (revision 1.1) with 471040K/53248K bytes of memory.
4 Gigabit Ethernet interfaces
31 Serial interfaces
2 terminal lines
1 Channelized E1/PRI port
8 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Cisco Unity Express 8.0.5 in slot/sub-slot 0/0
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Suite License Information for Module:'c2951'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2951'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
CMEGW-01#show inventory
NAME: "CISCO2951/K9", DESCR: "CISCO2951/K9 chassis, Hw Serial#: FCZ162420UU, Hw Revision: 1.1"
PID: CISCO2951/K9 , VID: V05 , SN: FCZ162420UU
NAME: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-1MFT-T1/E1 , VID: V01 , SN: FOC16020NTL
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC18044NBV
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC18044NCW
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32 , VID: V01 , SN: FOC16200WVB
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC162634FL
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9 , VID: V02 , SN: FOC162427JN
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC , VID: V03 , SN: DCA1612K0P8
Backup CME 2951
CMEGW-02#show ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.5(1)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 27-May-15 07:11 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
CMEGW-02 uptime is 3 hours, 45 minutes
System returned to ROM by reload at 10:47:27 gmt Mon Aug 22 2016
System restarted at 10:50:14 gmt Mon Aug 22 2016
System image file is "flash0:c2951-universalk9-mz.SPA.155-1.T2.bin"
Last reload reason: Reload Command
Cisco CISCO2951/K9 (revision 1.1) with 481280K/43008K bytes of memory.
Processor board ID FCZ2032B11W
3 Gigabit Ethernet interfaces
28 Serial interfaces
1 terminal line
4 Voice FXS interfaces
502992K bytes of ATA System CompactFlash 0 (Read/Write)
securityk9
datak9
uck9
cme-srst
cube
data None None None
CMEGW-02#show inventory
NAME: "CISCO2951/K9", DESCR: "CISCO2951/K9 chassis, Hw Serial#: FCZ2032B11W, Hw Revision: 1.1"
PID: CISCO2951/K9 , VID: V06 , SN: FCZ2032B11W
PID: VWIC3-1MFT-T1/E1 , VID: V01 , SN: FOC20218QE2
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC2024529Q
PID: PVDM3-32 , VID: V01 , SN: FOC20240UBD
PID: PWR-2921-51-AC , VID: V03 , SN: DCA2019K1TF
I read that to use switch commands I would need etherswitch module but I don't have it in the Primary CME.
Kind Regards
Michael
Solved! Go to Solution.
08-23-2016 06:49 AM
Yes that's a pure layer 3 router no layer 2 at all in place or else you would have a vlan output even if nothings configured
disregard that vlan 1 statement its not doing anything and it shouldn't be there , there is no requirement form looking at the config to even try replicate that , im still confused how its even there on primary as it layer 3 router maybe something to do with the ISM but I can confirm its not doing anything and does not require to be on the new backup router
CMEGW-01#show vlan
% Ambiguous command: "show vlan"
08-22-2016 06:29 PM
SVIs are can be created when the device has Layer 2 ports that can be configured to be part of the same VLAN as the SVI. The Cisco 2951 only have Layer 3 ports unless a Switch module is installed.
Could you please add a full 'show run' of your Primary CME Router?
08-23-2016 01:13 AM
08-23-2016 06:28 AM
hmmm there's no intervlan routing on that config and no vlans in use at all from what I see its pure layer 3 router no switching in place
and I agree with Hector you need a switching module to do SVIs on router as I have quite a view variations of them throughout our network
08-23-2016 06:32 AM
Hi Mark
On the primary CME there is
interface Vlan1
description $ES_LAN$
no ip address
I can't create one on secondary although it have almost the same iOS and hardware so am I missing something?
08-23-2016 06:37 AM
That's not in use no ip address on it , if svi has no ip address its no doing anything at L3
im still trying to figure how that's on a 2951 without an SM as I cant do it on any of mine that are pure L3
Do you have the syntax for this command ----show vlan ?
That will really tell confirm if its l2 at all as examole from one of my 2951s without an SM
XXXXXXXXXXX#sh vlan
% Ambiguous command: "sh vlan "
XXXXXXXXXXX#sh ver | i 295
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
System image file is "flash0:c2951-universalk9-mz.SPA.152-4.M2.bin"
08-23-2016 06:43 AM
Hi Mark
Primary CME
CMEGW-01#show vlan
CMEGW-01#show ver | i 295
*1 CISCO2951/K9 FCZ162420UU
CMEGW-01#show inter vlan 1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is a493.4ca7.ad03 (bia a493.4ca7.ad03)
Description: $ES_LAN$
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not supported
Last input 5w5d, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
8 packets input, 688 bytes, 0 no buffer
Received 8 broadcasts (0 IP multicasts)
5880 packets output, 452760 bytes, 0 underruns
0 output errors, 4 interface resets
8 unknown protocol drops
CMEGW-01(config)#interface vl?
Vlan
Backup CME
CMEGW-02#show vlan
CMEGW-02#sho ver | in 295
*1 CISCO2951/K9 FCZ2032B11W
CMEGW-02#show interfaces v?
Vif Virtual-PPP Virtual-Template Virtual-TokenRing
vmi
CMEGW-02#show interfaces vl?
% Unrecognized command
CMEGW-02(config)#interface vl?
08-23-2016 06:49 AM
CMEGW-01#show vlan
08-23-2016 06:58 AM
It was puzzling for me and I wasn't sure if it's needed but had some issues when connecting backup CME.
Now I rebuild it and it's working fine.
Thank you for your support.
