Unable to change vmedia policy
nick.talbot
I have 2 vmedia policies pointing to two vmware iso's (5.5 and 6.0).  When I attempt to change the vmedia policy from within the service profile, it looks like it accepts the change, the new vmedia policy is present after it submits.  Then if I try to click anything outside of the service profile I get
"There are uncommitted changes.  Are you sure you want to close the window and discard any changes"
I select "No" on this screen and just wait a while and the vmedia policy reverts to the old policy.
It's a relatively straight forward process, so I am not sure what I am doing incorrectly to get the new vmedia profile to change.
2 Accepted Solutions
Mohammed Majid Hussain
Try closing the UCSM off and restart it again ? (Give another browser a try, the CLI could be an option too)
-Majid
Wes Austin
Are you doing this through HTML5 GUI? There should be a "Save" button you press and then the changes should take effect.
If not, I would set the policy via CLI and see if the issue persists:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/cli/config/guide/2-2/b_UCSM_CLI_Configuration_Guide_2_2/b_UCSM_CLI_Configuration_Guide_2_2_chapter_011101.html#concept_7670DD2773BD4D6AA41CE1B636E6BE3C
HTH,
Wes
-Majid
Wes Austin
HTH,
Wes
