Expand column widith of table when using show commands
Peter Sheridan
Is it possible to dynamically expand the width of a table column when running certain show commands in IOS?
For example when running 'show int status' The output truncates the Name column (Refer to the attachment).
If it makes any difference, I am ssh'ing to the switches.
Peter
Milos Megis
Level 3
Level 3
I don´t know if it is possible to expand column width (probably not).
But you can display entire description with "show interface description" command
Hi Milos, Thanks. That's a handy command which does help. Regards, Peter
