Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929993members
1245234discussions
Community Activity
How Find Switch?
So, previously I had a static IP address I could point putty at that would SSH just fine. I verified the address in a Show Run form I copied two days ago, so I'm not crazy. The config was written to memory multiple times so it's not that.Today, after...
dxtrgerry by Level 1
  • 27 Views
  • 1 replies
DefaultProfile.xml in Cisco
Hi here,I'm looking for advice on editing my DefaultProfile.xml in Cisco and deploying it via policy to all Mac devices to establish a new connection. However, it seems that my Mac is retaining memory of the last successful connection, making it appe...
IP Phones 8864 or 8865 - No Audio Issue
Hi, When a call is made to 8.XXX.XXXX x1145 from a video phone on the A end in this case an cisco 8865 with x2222. The call establishes with auto attendant on the B end and then presented to the end user at x1145. The B end user picks up the call and...
AnyConnect NAM "Limited or No Connectivity"
Hi All,Recently we have deployed a NAC Solution with Cisco ISE in one of our customer sites."Limited or No connectivity" message appears randomly in AnyConnect NAM module (Wireless). This is not depend on the client laptop or wireless adapter as per ...
Lahiruk by Level 1
  • 4019 Views
  • 8 replies
  • 5 Helpful votes
Cisco 1010 ports not coming back on after reboot
I'm new to this so please be kind Setting up a Cisco 1010 Firepower device, unboxed it, got it up and running, havent' did any config yet, so its all the defaults I would say.  Needed to bring it to the office, once I turn it on, no port lights come ...
taitas by Level 1
  • 32 Views
  • 2 replies
  • 1 Helpful votes
Resolved! NTP and Syslog packets with specific IP Address
Hi All,I have a couple of C9300 L3 switches that are connecting to an ASA firewall. The NTP and the syslog server for the switches are located behind a firewall.When one of the switches request/send packets the gateway IP is the source address on the...
Ranjita by Level 1
  • 248 Views
  • 20 replies
VLAN changing
I have a strange one. C9200 switch, 17.03.04b. Setting up a port for a postage machine. config as follows:ip dhcp pool cin-6address 10.3.6.2 client-id 0100.1b00.4116.4dinterface GigabitEthernet1/0/15description Postage machineswitchport access vlan 6...
geocoles by Level 1
  • 23 Views
  • 1 replies
cannot get to privileged enable mode via console
After searching through other posts, my config seems OK but still strange behaviourasa 9.20 running on FPWR chasisI cannot get in enabled mode when connecting to ASA via console.It used to work but stopped after I played (disable and restore) with aa...
kewwa by Level 1
  • 315 Views
  • 17 replies
cisco isr 1116 port forwarding
Hello,I have a cisco router connected to ISP using Dialer interface. I can access the web no problem, but have problems configuring port forwarding to a local computer from outside. Trying with tcp port 5555.Any idea what I am doing wrong? Thanksvers...
maple1 by Level 1
  • 56 Views
  • 2 replies
