08-24-2016 07:46 AM - edited 03-17-2019 06:19 PM
A super sent me a screener asking why when she sent her agent a message, when he responded the time stamps didn't align? Both of their workstations times align correctly, jabber doesn't. She sent the message at 6:05 last night. He responded within a minute and it shows 5:06, an hour and 1 minute off.
Versions:
Super - Version 9.1.3 Build 13181
Agemt - Version 9.2.4 Build 4528
Any help is greatly appreciated. Thanks to all in advance.
Solved! Go to Solution.
08-25-2016 05:48 AM
i checked and suspect your jabber might be hitting the below defect.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur77577/?reffering_site=dumpcr
Could you try with latest jabber version 11.7 , if not latest then at least jabber version 10.6
08-25-2016 04:21 AM
Is this a first? Has anybody seen this before?
08-25-2016 05:03 AM
Ross, it would be worth to move this post to Jabber community wherein it will get more attention from the folks with experience on Jabber side:
https://supportforums.cisco.com/community/5831/jabber-clients
Deepak
08-25-2016 05:15 AM
Ok, can it be moved or should I just start a new discussion there? Thank you for responding, as always.
08-25-2016 05:17 AM
You should simply be able to move this post only.
Deepak
08-25-2016 05:41 AM
Great, I was able to move it. Hopefully I can find a resolution here. Thanks as always :)
08-25-2016 05:48 AM
08-25-2016 05:55 AM
Thanks Varundeep! I should've posted here to begin with. I suspected an upgrade might be in order. I will upgrade their client due to the bug report. Thank you for your help!
