08-24-2016 12:49 PM - edited 03-08-2019 07:08 AM
So I just received this new 4321 ISR and proceeding to configure it (replacing an aging 1841).
Mostly everything is working but I cannot get to SSH in it (so we don't use telnet anymore).
Here is the 'sh version' short output:
Cisco IOS XE Software, Version 03.16.02.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S2, RELEASE SOFTWARE (fc2)
Here is the 'sh ip ssh' output:
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
MAC Algorithms:hmac-sha1,hmac-sha1-96
Authentication timeout: 30 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 1024 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): ** rsa key **
The 'sh ssh' output:
%No SSHv2 server connections running.
%No SSHv1 server connections running.
And finally, the config (asterisks are censored info):
Current configuration : 2538 bytes
! Last configuration change at 19:15:40 UTC Tue Aug 23 2016
version 15.5
no platform punt-keepalive disable-kernel-core
hostname ********
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type t1 0 1
no logging console
enable secret 5 ********************************
enable password *********************
no aaa new-model
no ip domain lookup
ip domain name ******.ca
no ip dhcp use vrf connected
subscriber templating
license udi pid ISR4321/K9 sn ****************
license boot suite FoundationSuiteK9
username ********* secret 5 *************************
redundancy
mode none
controller T1 0/1/0
framing esf
clock source internal
linecode b8zs
cablelength short 110
channel-group 0 timeslots 24
vlan internal allocation policy ascending
interface Loopback0
ip address 10.0.137.10 255.255.255.255
interface GigabitEthernet0/0/0
ip address 192.168.160.20 255.255.255.0
ip nat inside
negotiation auto
no mop enabled
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface Serial0/1/0:0
ip address 192.168.0.2 255.255.255.252
ip nat outside
encapsulation ppp
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 192.168.20.0 255.255.255.0 192.168.160.254
ip route 192.168.30.0 255.255.255.0 192.168.160.254
ip ssh time-out 30
ip ssh version 2
access-list 1 permit 192.0.0.0 0.255.255.255
control-plane
line con 0
exec-timeout 30 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 30 0
login local
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
login local
ntp server 192.168.20.1
ntp server 192.168.20.150
end
So I can ping the host from my computer and I can telnet just fine. When I try to ssh, putty or linux host, all I get is 'Connection timed out' after a while. I turned on debug for ssh but nothing. Also, ssh from the router to itself works fine.
Any idea what is the trouble here?
08-24-2016 12:54 PM
I don't see the SSH keys in your config. Did you create them?
crypto key generate rsa
08-24-2016 12:59 PM
yes, it's there but I didn't post all (last line of 'sh ip ssh')
08-26-2016 05:30 AM
Hello
try zero sizing the local rsa key and re creating it then try again!
res
paul
08-24-2016 02:34 PM
Hi;
As part the SSH configuration is ok and you are running K9 IOS which is requirement for SSH.
Please try to do SSH from Router to itself to verify the SSH is working fine on Router. If it's work fine then the issue seems to be Firewall either exists inyour network or your PC.
Thanks & Best regards;
08-25-2016 05:50 AM
Please read the last line of my post...
Also, firewall isn't the issue because I can SSH anywhere else and connected via a switch on the same VLAN.
08-25-2016 06:06 AM
Hi;
If SSH works fine from Router itself, then for sure its Firewall issue.
If it's Cisco Firewall can you use the packet tracer and verify that firewall is allow SSH traffic to Router. In non Cisco firewall either enable the logging on policy where you allow SSH for Router or use alternate tool of packet tracer.
08-25-2016 06:13 AM
Again, no firewall in between and the request doesn't even reach the router ('timeout', not 'refused') as per debug.
I tried crossover and it worked so it's something with our aging switch. Will do some more testing but I'm confident it will work.
